The Story Behind the Problem :
I recently got an alienware ! :) (yay !) but...
i smashed my pc monitor though :(
so i found my ipad lying around the house so i decided to use it as my Monitor :)...
[see Attachment 1]
but again....
i decided to play Black Flag ...
The game worked but....
It was tooooooo Laggy because it was "NOT" using my GPU inside (GTX 760ti OEM)....
The Actual Question :
                                Is there any software out there that could direct the my GPU's Graphic Rendering Capablities to a monitor that is "NOT" connected to the GPU itself ?!!1
https://linustechtips.com/topic/294378-graphics-problem-need-a-software-help/
Nope, doesn't exist as far as I'm aware. At least not with DirectX games. I suggest next time you don't break your monitor.
[see Attachment 1]
but again....
Answer: Nope.
nope :3
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
I told you, you need to work on that anger management. :P JK
Seriously though, how'd you break it?
@Sri Ganesh
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
Why did you smash your monitor...
Inadequate anger management. :P JK
The problem isn't so much software, or graphics card, it's the fact that the ipad can't be connected to the graphics card.  Looks like it's going through the usb ports on the back (nice workaround btw.) It's why most premade systems with discrete graphics cards actually block off all the motherboard video outputs.
BTW I actually run my grapics through a 42 inch 1080p TV. I found one of those rare ones capable of 200Hz
no
But, how are you using your iPad as your monitor via USB?
Oh, and make sure to follow your topics, and quote people
Having problems with your fresh Windows 10 install? PM Me!
Windows 10- Want To Disable Telemetry, Disable Cortana, Disable Windows Updates? Look at my guide HERE
LTT Beginners Guide  | Community Standards | TN&R Posting Guidelines
OMG thanks For all those quick replies guys ! :D
Well i was not angry when i smashed my Monitor !:D Just didn't like its shape :P !
BTW i heard about some software on Gigabyte website where u could use graphics regardless of which port u use....
and it was some of glitch used for 3dMark for fps ...
Common guys there must be something virtual graphics booster :P (just came up with a name )
1. why did you get an alienware?
2. make sure the drivers are installed
3. is it plugged into the write port?
yeah, no. And why did you make another topic identical to this?
 Edit- Cool, threads merged!
He's most likely not; he's probably using Remote Desktop, so streaming a game is slow because it isn't meant for that. The cable is probably just for power :D
that is exactly what i was thinking. He is probably using TeamViewer and assumes the data is being transferred via the USB  :lol:
@GeekZoid sorry my mistake :P i will delete this right away ! ;) thanks
My name has an "a" in it. ;)
not Team Viewer its twomonusb
Oh, wow. that is pretty cool, and i have no idea if you can use that with your 760. Probably not.
