@Geekazoid :P using my iPad here and I'm quite blind too :P
:P
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
@Kherm well I use my ipad as the main monitor :P and i works pretty good !
 is there anything like virtuial monitor graphics manager :P
i'm afraid not, does a DP to USB exist? Because you could finagle a way to plug your Ipad into the adapter then the adapter into the GPU
Having problems with your fresh Windows 10 install? PM Me!
Windows 10- Want To Disable Telemetry, Disable Cortana, Disable Windows Updates? Look at my guide HERE
LTT Beginners Guide  | Community Standards | TN&R Posting Guidelines
