CPU bottleneck? I need advices
Thanks everyone,
thanks for your advice, would you mind explaining to me why the 1100t is better than the fx-6300 for gaming? Thanks!
because believe it or not your phenom chip has higher IPC (instructions per clock) therefore if you can bring it in the ballpark of any FX in terms of frequencies it will perform better.
Piledriver and bulldozer architecture was a step back from AMD in terms of raw per core performance and this is crucial to gaming...they tricked the architecture using long pipelines in order to be able to reach high frequencies and have 4.0ghz and 5.0ghz CPU's that would be appealing to customers but the performance is just not there (this of course is the whole thing in a nut shell theres a lot more to it but that's all you have to know about this.)
Modern haswell CPU's from intel gets almost twice the performance per core when compaired to an AMD CPU running at the same clockspeed, therefore they are MUCH better gaming chips.
Also games typicaly won't fully use multi-core CPU's and the AMD FX are based on ''modules'' or what they call CMT and the ''8 core'' and ''6 core'' CPU's are really only 4 modules and 3 modules...as opposed to your phenom which is a ''real'' 6 core CPU.
