it does not bother me but is a bit annoying
So it does bother you :P And what is your monitor? Did you overclock any of your hardware that could have caused artifacting?
[-] i7 4790k @ 4.7ghz [-] Asus Maximus VII Formula [-] EVGA Gtx 980 Sc [-] Corsair H105 [-] Corsair Obsidian 750d [-]
https://pcpartpicker.com/user/TBNRunity/saved/#savedbuild_1797964
https://linustechtips.com/topic/292952-texture-help/#findComment-3978013
I'm using an benq 1080p monitor non of my hardware is over clocked and I'm using Intel's 4600 graphics if that is any help
My speakers dont even fit on or under my desk...PA's FTW
https://linustechtips.com/topic/292952-texture-help/#findComment-3978099
"We’ve encountered some graphical glitches right from the start. Thankfully, though, those glitches can be easily fixed. So, if you are encountering red dots in DX11/10 mode, you’ll have to set both AA and AF – in Nvidia’s Control Panel – to ‘Application Controlled Mode’. If, on the other hand, you’re encountering some awful black character textures in DX9 mode, all you have to do is set the Negative LOD Bias setting – again in Nvidia’s Control Panel – to ‘Allow’. These settings are essential so make sure you’ve made those changes to Saints Row: The Third’s profile before running the game.
So to fix red artifacts in DX11/10 mode , set Anti-Aliasing and Anisotropic Filter to "application controlled" in the Nvidia Control Panel.
To do that just basicaly right click on your desktop and open up "Nvidia Control Panel"
In Nvidia Control Panel to the top left choose "Manage 3D settings"
For "Global Settings Tab" make sure those two things mentiond AA and AF are set to application controlled
For "Program Settings Tab" , find Saints Row The Thirds profile or add in the games executable (exe) if its not there, and again set AA and AF to application controlled.
See if that works
Beneath this mask there is more than flesh. Beneath this mask there is an idea, Mr. Creedy, and ideas are bulletproof.
As I get older I get angrier more cynical, meaner. I feel some warning posts coming. I feel a ban coming. I was warned.
CPU-i5 2400 GPU-Sapphire Radeon HD 7970 OC Mobo-H67MA-D2H-B3 Ram-G.Skill Ripjaws 8gb 1333mhz Case-Fractal Define R4 PSU-Corsair CX750 Storage-Samsung EVO 250gb, 1tb WD Black,Hitachi 1tb Other stuff-Corsair K90, M90 Cooling-3x 140mm Fractal fans Sound-Sennheiser HD438 headphones
https://linustechtips.com/topic/292952-texture-help/#findComment-3978106
See if that works
@scobie56
I'm using intel HD 4600 graphics
https://linustechtips.com/topic/292952-texture-help/#findComment-3978139
Intel graphics has a control panel with that sort of stuff doesn't it?? In the bottom right where the internet connection ect is displayed.
https://linustechtips.com/topic/292952-texture-help/#findComment-3978156
