Here is my specs.. intel i5 4690k(i will overclock), asus maximus vii hero z97, gigabyte gtx 970, g.skill ripjaws x 2 8gb sticks, corsair h100i water cooler, dvd rw, samsung 850 evo 250 gb, corsair spec 03 case. (I need help finding what wattage psu i need thks) if I forgot to mention anything just tell me. edit: ( will a 650 watt corsair psu work fine? I am gonna overclock the cpu and gpu)
https://linustechtips.com/topic/292296-need-help-with-wattage/
Why got so much high-end stuff then get such a trash case? You should get a better case than that
Also if you want SLI in the future (And both GPU's OC'd) I recommend the EVGA G2 750W
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/292296-need-help-with-wattage/#findComment-3970088
650w PSU should be suffice, and have room for both overclocking, and expand ability.
Just remember: Random people on the internet ALWAYS know more than professionals, when someone's lying, AND can predict the future.
i7 9700K (5.2Ghz @1.2V); MSI Z390 Gaming Edge AC; Corsair Vengeance RGB Pro 16GB 3200 CAS 16; H100i RGB Platinum; Samsung 970 Evo 1TB; Samsung 850 Evo 500GB; WD Black 3 TB; Phanteks 350x; Corsair RM19750w.
Laptop: Dell XPS 15 4K 9750H GTX 1650 16GB Ram 256GB SSD
sex hahaha
https://linustechtips.com/topic/292296-need-help-with-wattage/#findComment-3970089
500w would work. 650W sli no OC, 750w if you would want to sli and overclock.
https://linustechtips.com/topic/292296-need-help-with-wattage/#findComment-3970148
Case doesnt affect preformance (except maybe cooling) but other than that I dont see any need to spend money on an expensive case because I do not care about looks
https://linustechtips.com/topic/292296-need-help-with-wattage/#findComment-3970177
Then get the Arc Midi R2 non-window version, minimalistic case but with fantastic airflow which is great for cooling. I recommend it because cooler components = longer lifespan
https://linustechtips.com/topic/292296-need-help-with-wattage/#findComment-3970187
that is a $100!!! like i said i dont care about looks and the case i chose has good airflow
https://linustechtips.com/topic/292296-need-help-with-wattage/#findComment-3970199
It has mediocre airflow at best really
Also holy balls the price on the arc midi has increased a lot. It was on $70 (No MIR/Promo) a while back
https://linustechtips.com/topic/292296-need-help-with-wattage/#findComment-3970209
oh ok xD
I'll try to find a slightly better case for the money, give me a moment
https://linustechtips.com/topic/292296-need-help-with-wattage/#findComment-3970233
oh ok xD
http://pcpartpicker.com/part/nzxt-case-cas340wb1
Better case for airflow because of the positioning of the front fans and about as expensive
And also since you are active atm is a corsair 650 watt power supply good enough for overclocking my cpu and gpu? I kind of thought 750watt was a little overkill
It's enough but if you maybe want to SLI in the future I recommend going with the EVGA G2 750W
https://linustechtips.com/topic/292296-need-help-with-wattage/#findComment-3970239
A good quality ~500w PSU would be able to power your system.
Can you provide a link to where you are buying from and a budget for it? We may be able to find a better alternative for you. Also, which specific 650w PSU are you looking at from Corsair?
https://linustechtips.com/topic/292296-need-help-with-wattage/#findComment-3970268
The HX series one
https://linustechtips.com/topic/292296-need-help-with-wattage/#findComment-3970276
The HX series one
If you will not SLI in the future then I would go for the Corsair CS550M, EVGA 500B, Seasonic X/G-series 550 or similar.
Otherwise if you might SLI then get the EVGA G2 750W
https://linustechtips.com/topic/292296-need-help-with-wattage/#findComment-3970300
I like the case but I do not think it can fit my h100i at the top of it :(... thank you for all your help btw.. And if I go with the 750w psu wont it dev=crease my performance by a little? because if I ever do sli (which almost certainly wont) it wont be until a long time
https://linustechtips.com/topic/292296-need-help-with-wattage/#findComment-3970309
It will not decrease your performance at all
https://linustechtips.com/topic/292296-need-help-with-wattage/#findComment-3970314
The HX series one
Budget and links to store? I asked availability and pricing may differ depending on your region. For example, prices / availability  in the AU / NZ is different from the US.
Anyways, the HX650v2 is a good unit. It's a Seasonic G unit internally; however, it lacks the native connectivity to SLI (only has two PEG connectors as opposed to four). The Seasonic G and XFX XTR 650w (based on the same platform as well, but offer full modularity, a FDB fan, and a semi-passive cooling design) has four native PEG connectors, and should be in the same price point.
Edit: since you probably aren't going to SLI, I guess connectivity in regards to it is irrelevant.
https://linustechtips.com/topic/292296-need-help-with-wattage/#findComment-3970325
ok well I have decided and I do not plan on doing sli ever. so which psu do I need to get? ( sorry if im making you repeat yourself)
CS550M, EVGA 500B or CX500M
Out of these I would go CS or EVGA
https://linustechtips.com/topic/292296-need-help-with-wattage/#findComment-3970368
Out of the three that Archangel had mentioned, I go with the CS550M. It's the best performing unit of the three electrically (the utilization of DC-DC would offer better voltage stability at a wider range of loads in comparison to the entry level, group-regulated design of the EVGA B and Corsair CX).
https://linustechtips.com/topic/292296-need-help-with-wattage/#findComment-3970381
ok guys thank you so much for the help :).... How many watts do you think my system will be using (average)
https://linustechtips.com/topic/292296-need-help-with-wattage/#findComment-3970403
About 250W under load
https://linustechtips.com/topic/292296-need-help-with-wattage/#findComment-3970413
