Im currently running an i7 4790k at stock speeds with a CM Hyper 212 Evo but I was wondering if it's worth upgrading my cooling solution (to perhaps dabble with some overclocking). I don't have low profile ram and my case supports most radiator sizes (It's a Corsair Air 540). Any upgrade suggestions? Thanks.
https://linustechtips.com/topic/292028-upgrade-cooling/
NH-D15 for air cooling (Handles high-profile RAM without a problem)
Kraken X61, Swiftech H240-x, Corsair H105/110 for AIO
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/292028-upgrade-cooling/#findComment-3966517
I swear by Corsair for watercooling and found that an AIO gives good OC potential. Worth the investment.
i5 4690K | Asus Ranger VII | 8GB HyperX Fury | Asus GTX 780 | NZXT H440 | Samsung 850 Evo | Seagate Barracuda | Corsair RM 750W | Corsair H105
E3-1246 v3 | Asus Gryphon Z97 | 8GB HyperX Fury | MSI GTX 970 | Enthoo Evolv mATX | Samsung 840 Evo | WD Red | EVGA SuperNova GS 650W | NZXT Kracken x41
https://linustechtips.com/topic/292028-upgrade-cooling/#findComment-3966553
^ I agree with this.
CPU: i7 4790K @ 4.7GHz | Mobo: MSI Z97 MPower Max AC | RAM: 16GB Kingston HyperX Beast 2400MHz | GPU: MSI GTX980 Gaming 4G TwinFrozr V | Case: NZXT Switch 810 SE | Cooler: Corsair H105 Hydro |
SSD: Samsung 850 Pro 512GB | Storage: WD Caviar Black 3TB | Displays: Samsung P2450 & Samsung 2232GW | Keyboard: Tesoro Colada G3NL Black Aluminum (Cherry MX Brown)
https://linustechtips.com/topic/292028-upgrade-cooling/#findComment-3966703
