It's safe.
https://linustechtips.com/topic/29180-good-voltage-for-haswell/#findComment-371262
It doesn't matter. just keep the temp @ 80-85 degreeds. Haswell limited is by thermal disipation and NOT a voltage wall.
FX8320 4.2Ghz@1.280v& 4.5 Ghz Turbo@1.312v Thermalright HR-02/w TY-147 140MM+Arctic Cooling 120MMVRM cooled by AMD Stock Cooler Fan 70MM 0-7200 RPM PWM controlled via SpeedfanGigabyte GA990XA-UD3Gigabyte HD 7970 SOC@R9 280X120GiBee Kingston HyperX 3K2TB Toshiba DT01ACA2001TB WD GreenZalman Z11+Enermax 140MM TB Apollish RED+2X Deepcool 120MM and stock fans running @5VSingle Channel Patriot 8GB (1333MHZ)+Dual Channel 4GB&2GB Kingston NANO Gaming(1600MHZ CL9)=14GB 1,600 Jigahurtz 10-10-9-29 CR1@1.28VSirtec High Power 500WASUS Xonar DG, Logitech F510Sony MDR-XD200Edifier X220 + Edifier 3200A4Tech XL-747H 3600dpiA4Tech X7-200MPdecent membrane keyboardPhilips 236V3LSB 23" 1080p@71Hz .
Sorry for my English....
https://linustechtips.com/topic/29180-good-voltage-for-haswell/#findComment-371302
Yep keep the Temps. down.
FX8120 @ 5.0GHz | Sabertooth 990FX | Patriot Viper Xtreme 8GB @ 2133MHz | Powercolor HD7950 @ 1300/1800 | Bitfenix Shinobi XL Modded | Corsair AX850 | Mushkin 120GB & Seagate 2TB | Bitfenix Recon | 5X SP120 PE | 6X Yate Loon 120mm HS
Koolance 200 Res | 2X Koolance 360 Rads | Danger Den CPX Pro | EK 7950 Block | Koolance CPU Block | Bitspower & XSPC Fittings
Green Machine
https://linustechtips.com/topic/29180-good-voltage-for-haswell/#findComment-371310
ok thank you,
now im trying to lower the voltage as much as i can but still keep stability.
i really wanted 4.5GHZ,
but i'd need to reach like 1.35V for that and the temps would go crazy...
even though i have a H100i....
It seems you don't ave a very good chip, and you would need a custom loop for that kind of voltages, i would honestly give up, and try to find a stable 4 ghz - 4.2 and go uncer 1.3, the temps are insane if you don't have custom loop
System
CPU: i7 4770kMotherboard: Asus Maximus VI HeroRAM: HyperX KHX318C9SRK4/32 - 32GB DDR3-1866 CL9 / GPU: Gainward Geforce GTX 670 Phantom Case: Cooler Master HAF XBStorage: 1 TB WD BluePSU: Cooler Master V-650sDisplay(s): Dell U2312HM, LG194WT, LG E1941
Cooling: Noctua NH-D15Keyboard: Logitech G710+Mouse: Logitech G502 Proteus SpectrumSound: Focusrite 2i4 - USB DAC / OS: Windows 7 (still holding on XD)
https://linustechtips.com/topic/29180-good-voltage-for-haswell/#findComment-371813
I resolved to running the CPU at 4.2GHZ on 1.25V,
I don't really need the extra performance,but i did want to squeeze all the juice out of it.
https://linustechtips.com/topic/29180-good-voltage-for-haswell/#findComment-371825
Smart, don't kill your chip if you don't really have to, keep the temps low, your cpu will be awesome for a long time, and the few fps lower than 4.5 ghz but still strong
System
https://linustechtips.com/topic/29180-good-voltage-for-haswell/#findComment-372523
after thoroughly testing a 4770k for a week heres what i would recommend.
0V-1.3V For people concerned about volts\heat. up to 1.3V is playing it SAFE. be happy with your clocks at 1.3V. using an air cooler. I have found that up to 1.3V will offer the best performance ratio in terms of GHz\Watt
1.3V-1.44V Still safe without risking CPU degradation . Requires a good cooling solution ( top notch AIO cooler) NOT recommended for people using air cooling or people concerned with heat or volts applied
1.45V and Higher. For extreme Overclockers only. from my testing going over 1.45V to achieve higher clock speeds is pointless. the performance\Watt drops heavily and massive amounts of heat is generated.
Mainboard Asrock Z170 OCF CPU 6700k RAM Tridentz 3600 HDD Intel 730 240gb GPU GTX 780ti sc acx PSU Silverstone Strider 1200W  Case Antec 900 Laptop Lenovo Thinkpad T520 build log-   http://linustechtips.com/main/topic/35809-antec-900-the-re-birth-of-a-legend/ Check out the Tech Center https://www.youtube.com/user/prokon24/videos LTT's Unicore King
https://linustechtips.com/topic/29180-good-voltage-for-haswell/#findComment-372651
first time mounting a radiator\block is annoying,
im sure second time it will be much easier  :D
lol it's not that but more like the moutning bracket that corsair provide with the H100i you need to thigh it up really good or else the cooler will hang above the cpu for like 1/2mm and that cause higher temps because the contact won't be good at all
https://linustechtips.com/topic/29180-good-voltage-for-haswell/#findComment-373503
In the wise words of that Asus representative that I fail to remember his name "You'll not be wanting to go over 1.275V"
Console optimisations and how they will effect you | The difference between AMD cores and Intel cores | Memory Bus size and how it effects your VRAM usage |
How much vram do you actually need? | APUs and the future of processing | Projects: SO - here
Intel i7 5820l @ with Corsair H110 | 32GB DDR4 RAM @ 1600Mhz | XFX Radeon R9 290 @ 1.2Ghz | Corsair 600Q | Corsair TX650 | Probably too much corsair but meh should have had a Corsair SSD and RAM | 1.3TB HDD Space | Sennheiser HD598 | Beyerdynamic Custom One Pro | Blue Snowball
https://linustechtips.com/topic/29180-good-voltage-for-haswell/#findComment-375475
Was it JJ? If it is he use to design motherboards and such so believe him when he says something like that.
https://linustechtips.com/topic/29180-good-voltage-for-haswell/#findComment-375487
O.o I think so, he was on TechofTommorow and Teksyndicates channel.
https://linustechtips.com/topic/29180-good-voltage-for-haswell/#findComment-375524
Yeah him. My favorite Asus rep. is still patty.
Awesome 500 posts now if I could catch up with Joelthezombie15...
https://linustechtips.com/topic/29180-good-voltage-for-haswell/#findComment-375528
I get 4.6 at 1.27
I'm happy with that.
https://linustechtips.com/topic/29180-good-voltage-for-haswell/#findComment-375536
I get 4.6 at 1.27
Nice voltage
https://linustechtips.com/topic/29180-good-voltage-for-haswell/#findComment-375569
I get 4.6 at 1.27
Got a better part of the silicon.
https://linustechtips.com/topic/29180-good-voltage-for-haswell/#findComment-375573
