Hello everyone! My first post here ;)
I am going totally overkill with my new watercooled build. I am stuffing 2x 480mm radiators in a Phanteks Enthoo Primo case. I am doing pull on the rads. I need to find out the quietest fans on the market. I dont care about the CFM, I just care about the noise. They will all be running at the lowest setting. I want to achieve the quiet system build. Can you provide me with some links? I live in the UK.
Thanks!
See my blog for amusing encounters from IT workplace: http://linustechtips.com/main/blog/585-life-of-a-techie/
https://linustechtips.com/topic/290716-quietest-static-pressure-fan/
No those black Noctua fans are not quiet even at lowest RPM. You have to get the regular beige ones. (I have both types)
If you want a pull setup, then putting fan shrouds between the radiator and the fans (if space allows) will make them quieter.
I also think for pull at minimum RPM with shroud with no exhaust restrictions, the NF-P12 may be better than NF-F12. I would still go with the NF-F12 since they are more versatile in case you change your setup in the future.
There may be better fan options out there for minimum RPM in a pull config, but unfortunately not many reviews are done with that setup.
I am not so up to date with noctuas..
depending on location:
states: rosewill hyperborea - http://www.newegg.com/Product/Product.aspx?Item=N82E16835200068
aboard: akasa apache - http://www.amazon.com/Akasa-Apache-Cooling-S-Flow-Design/dp/B003H04XEY/ref=sr_1_1?ie=UTF8&qid=1421275860&sr=8-1&keywords=akasa+apache
600-1300 rpm
2.76 mm/h2o
16 dBA
all black works as case fans too.
I second the Akasa Apache Blacks, they are almost silent when run at full speed.
Noctua fans are great, but very pricey and can be very loud if you run them at full speed.
Alternatives include BeQuiet Shadow Wings (or pure wings), Noiseblocker eLoops or Scythe Grand Flex (or gentle typhoons if you can find them).
If you have any questions about specific fans feel free to ask, best of luck :)
"PSU brands are meaningless, look up the OEM."
I am addicted to building gaming PCs but I don't have a great reason to stop...yet...
I forgot to mention that I need them to be PWM. I love the noctua performance but the poop brown just puts me off. The Apache blacks look promising... I'll order one and have a look! :)
The black noctua fans can be controlled to lower rpms, so it isn't as big a deal for noise. Check up on linus's video on that and he would suggest the 2000 rpms without much issues if set up right.
Still new, but learning
i7 4790K / GTX 970 G1 Gaming / Maximus VII Hero / Swiftech H240x / Corsair Vengeance Pro 16gb, 1600mhz, cl9 / 850 evo 250GB /
WD Blue 1TB / HX850 / Phanteks Enthoo Pro
considered by who?  from personal experience, they are not.  I have 3, ended up taking them out of my build.
600-1300 rpm
2.76 mm/h2o
16 dBA
sure specs look great, and actual air noise is low.  but at low speeds they produce a very audible clicking noise.  I have both 120 and 140 mm versions laying around cause I ended up not using them
almost silent at full speed?  when in the next room... even then, maybe
to OP
from personal experience, rpm to noise ratio, here's the order I'd put the fans in for going for the quietest setup
Scythe Gentle Typhoons - I have 1850 rpm version and they undervolt great down to 400-500 rpm, become audible around 900 rpm.  these are above the eLoop cause it feel like they move more air per rpm (hand test, nothing scientific) and can be used in both push and pull.  and undervolt better.  and cheaper if you
Noiseblocker eLoop - can only be used in push, become audible around 900 rpm
Noctua AF14 (140mm fan)
Noctua NF-F12 - becomes audible around 750-800 rpm, also considerably louder than the others at 1000 rpm
Akasa Apache - I wouldn't use these if you plan to run under 1000 rpm.  but if you do plan at running at 1000 rpm I think these are the best.  they're about the same on loudness, the ticking goes away, and they move way more air than any of the other fans.  I may be doing the non scientific hand in front of fan test, but there's no doubt that these move the most air per rpm of any fan I've tried.
HP something | 5600X | Corsair  16GB | Zotac ArcticStorm GTX 1080 Ti
CaseLabs SM8 | EK Supremacy | UT60 420 | ST30 360 | ST30 240
Gentle Typhoon's and Noctua's and Noiseblocker eLoop's
from my personal experience of 11 hyperborea 120mm fans in a system at
600-1000 rpm i have none of what you had described. via PWM or static
voltages.
on that note, all 20 of my AP/GT-15 deffo have a click or grind when volting
less than 8.2v. via fan controller or resistors. similar to the noctua PWM moan
at less than 70%, can be best described as a capacitor surge on/off.
voltages.
Maybe the hyperborea are better than the akasa's... I just assumed they were the same. All 3 of my akasa's are like that and my 5 gentle typhoons are not...
I tried all my fans off a mobo header and a lamptron fan controller, the kind with the knobs
EK Vardar fans
Specs: 4790k | Asus Z-97 Pro Wifi | MX100 512GB SSD | NZXT H440 Plastidipped Black | Dark Rock 3 CPU Cooler | MSI 290x Lightning | EVGA 850 G2 | 3x Noctua Industrial NF-F12's
Bought a powermac G5, expect a mod log sometime in 2015
Corsair is overrated, and Anime is ruined by the people who watch it
