white asus z97 pro heatsinks
InVeyd
Im building a black and white build and im not sure what to do with those gold heatsinks. Should I spray paint it? What product should i use?? Or should i use a vinyl? Thanksss
Use plastidip. A sort of rubber coating. Linus made a video where he painted components with plastidip.
"I fart in your general direction" -The Frenchmen
Ignoring heat dissipation, i would use PlastiDip. If the mobo breaks and you need to do an RMA you can just peel off the paint.
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
Thats a gud idea! Lol
I just built a system using the Z97 Pro motherboard the gold accents on theheatsink come off from the lower black portion so you can paint or plasti-dip them very easily, I personally wrapped them in carbon fiber but if you plan to do that be sure to set aside a couple of hours since they are fairly intricate. They don't contribute too much to heat dissipation since the contact between the lower and upper doesn't even have thermal pads or compound to transfer between them readily.
I think it's going to be better if you sand them and polish (of course it's going to loose its warranty). This way you get sick looks and retain the thermal dissipation.
