Hi Guys,
I'm going all out with a new Hackintosh build which will be primarily used for video production and gaming. It's an overkill build but fortunately I got lucky enough to go a bit wild with my budget.
I've based the build off the Tonymacx86 site... can anyone see where there may be a problem with the build?
CPU - Intel Core i7-4790K 4.0GHz Quad-Core
Motherboard - Gigabyte GA-Z97X-UD5H-BK ATX LGA1150
CPU Cooler - Corsair H100i 77.0 CFM Liquid
Memory - Corsair Dominator Platinum 16GB (2 x 8GB) DDR3-2133
Storage - Samsung 850 Pro Series 512GB 2.5" SSD (<-- dual partition to boot both ios and windows)
                Western Digital BLACK SERIES 4TB 3.5" 7200RPM (for storage)
Video Card - Gigabyte GeForce GTX 970 4GB WINDFORCE
Case - Corsair 750D ATX Full Tower
Power Supply - SeaSonic 860W ATX12V / EPS12V
Optical Drive - Pioneer BDR-209DBK Blu-Ray/DVD/CD Writer
Wireless Network Adapter - TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1
Monitor - Asus PA279Q 27.0"
I'd be glad to hear any and all thoughts on this build and definitely open to criticism.
Cheers,
Fosco
https://linustechtips.com/topic/289191-project-sandyland/
Hackintosh gaming
pick one man ^^ that's the problem I see with this build. If you plan on dual booting windows then it's great. 4tb drives have pretty high failure rates though, you might want to consider 2 2tb drives instead.
sudo chmod -R 000 /*
https://linustechtips.com/topic/289191-project-sandyland/#findComment-3926249
Looks fine but your overspending on some of the parts id say unless doing lots of overclocking
It's overspending whether the system would be oc'ed or not.
What's the system being used for? Why not post a pcpartpicker permalink?
Dominator Platinums are a waste of money. Is the bluray drive really necessary?
https://linustechtips.com/topic/289191-project-sandyland/#findComment-3926257
I was talking about the motherboard and CPU cooler. Dont forget, I'm dumb :D
Steve
https://linustechtips.com/topic/289191-project-sandyland/#findComment-3926264
It's OS X, not iOS.
https://linustechtips.com/topic/289191-project-sandyland/#findComment-3926367
Wow you guys are fast! :-)
Ok replying on my phone so if I miss anyone I'll try and respond when I get back to a pc.
The build is for a number of reasons. I fell in love with Lupos custom sleeving and the whole making the insides of a pc look awesome. That's where the dominators come in, yes they're expensive but they look fantastic. Like I said I got lucky with a ridiculous budget for the build $5k...
I'm also dual booting as most of my house is apple, the ease of multimedia networking was too good to pass up. Not that it doesn't come with its own problems, but I'm so far down that track that I'm cool with the good and bad. Also, I'm interested in the challenge of building a pc that's also a Mac. I work on a PC at work so can continue with work stuff at home. But can also control my media world as well.
The build is also to do a lot of video editing. I have hours and hours of HD GoPro footage to create with. The BluRay is mostly so I can rip my BluRay collection. It's not that expensive so worth being able to get my bluray vids into my media collection.
Thanks for the advice on the 4TB drives! I'm thinking about setting up a raid 10 config down the track so a series of 2TB drives?
Without being able to see all of the threads on this phone I hope I've answered everyone's questions...
Cheers,
Fosco
Oh that's right, Sandy Bridge... Though that might happen. Sandyland is the name I use for all my devices and medics centre. They're all SandySomething. :-)
https://linustechtips.com/topic/289191-project-sandyland/#findComment-3926453
Thanks Godlygamer... Had a brainfart... It is Monday morning after all! ;-)
It's Sunday here on the East Coast. No problem.
https://linustechtips.com/topic/289191-project-sandyland/#findComment-3926466
Laputacake, yes I'll be overclocking...
Well, I'm on my phone too so I can't make a list, but I'd day spend less on your motherboard, RAM (yes it looks pretty but so is other much cheaper ram and just because you have a massive budget doesn't mean you need to fill it.), go for the h105(thicker rad so better cooling) and of you need any help whilst installing mac os I'll try to help.
Steve
https://linustechtips.com/topic/289191-project-sandyland/#findComment-3926515
OK so i've taken on board everything everyone has to say and come up with a slightly different build...
http://au.pcpartpicker.com/user/Skid_Mk_II/saved/GLB48d
Oh, I just came across this thread again and noticed you bought pretty much everything already.
As for why you didn't get much feedback.. You need to quote a post or tag a member or else they won't get a notification you replied to them.
https://linustechtips.com/topic/289191-project-sandyland/#findComment-3975874
OK, thanks for replying anyway. :-) Looking forward to building this...
https://linustechtips.com/topic/289191-project-sandyland/#findComment-3981873
