I have two questions and was hoping you could help me out on them.
1. How can I tell how old the hard drive I was just given is? It's a Toshiba MK1246GSX, and I can't seem to find anything on the drive to tell me how old it is. And I don't have a computer I can throw it in to check.
2. I need an OS for Apollo (which is in my sig, so check it out). But I don't know what I want. I would like one for music and stuff, but I don't know of anything that would run on hardware that old.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/288381-two-questions/
1. There's usually a date on it.
2. idk
But I can't seem to find one. :( Toshiba is a cunt.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/288381-two-questions/#findComment-3915814
1. But you can see how many hours your HDD powered on till now using Speccy
2. Why not XP? or Ubuntu (run some older version)
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/288381-two-questions/#findComment-3915865
1. I can't put it in a computer to check.
2. XP doesn't seem as though it wants to activate now. And I had kinda forgotten about Xubuntu.
Lubuntu, Puppy Linux or DSL (Damn Small Linux). You could also get a task manager based distro with no concrete UI.
Honestly, those are the only things that have the chance of running even remotely well on your computer.
Puppy ran well, but media was a pain in the ass.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/288381-two-questions/#findComment-3915882
It appears to be a Parallel ATA drive.  Between the interface, capacity, and seeing 2006 drivers for it, I'd say it's about 10 years old.    I should give you the parallel enclosure I have and never used.
https://linustechtips.com/topic/288381-two-questions/#findComment-3917254
It's SATA.
Download CrystalDiskInfo, it will tell you the power on hours.
Again, I don't have a computer I can put it in right now. It's only like the 4th time I've said this.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/288381-two-questions/#findComment-3917550
