My friend wants a budget gaming rig to rival the PS4.  I am fine with used and refurbished parts.  The only requirements are as follows:
-Must have at least a 7870 or 660 ti (used for good price)
-4 GB of RAM (Im giving him some and used)
-AMD upper quad core or lower six core (definitely not used)
-aftermarket cooler
-semi modular
i5 4670k| Asrock H81M-ITX| EVGA Nex 650g| WD Black 500Gb| H100 with SP120s| ASUS Matrix 7970 Platinum (just sold)| Patriot Venom 1600Mhz 8Gb| Bitfenix Prodigy. Build log in progress
Build Log here: http://linustechtips.com/main/topic/119926-yin-yang-prodigy-update-2-26-14/
https://linustechtips.com/topic/28807-help-on-gaming-rig-under-550/
Just a thought, but how about some doing some research yourself?
No offense, but you seem to have some knowledge. I don't mind helping people who have no idea where to start or if someone got a specific problem.
Christopher Kruse | Webdeveloper (Interface & Applications)
i7 3770k (3233C Batch) @ 4.2ghz | Asus P8Z77 WS | Gigabyte 780 Ti OC  | Corsair Vengeance LP 1600 32GB DDR3 | Samsung 850 EVO 500GB +2x Samsung 840 EVO 250GB + Samsung 830 256GB + 4x WD30EFRX, 2x WD30EZRX, 1xWD20EARS | Corsair AX750 + Bitfenix Extensions | Fractal Design Define XL R2 + Xigmatec 3in3 Hotswap Cage | Noctua NH-D15 + Thermal Grizzly Kryonaut, 5x Noctua NF-P14s redux-1500 PWM | Peripherals: Logitech G502 + Corsair K70 RGB + Red 40A-L O-Rings | Sound: Denon AVR 2807 via HDMI + 2x Nubert nuPro A-20 + 1x B&W CC6 Center | SoundMagic E10 | Jabra Speak 410
I have done quite a bit actually.  I want to see what other people come up with.
Well, how about presenting it? :) It's not like people will mindlessly agree with your ideas, just because you posted them.
Go 7870 XT for the GPU.  As for a CPU, an FX-6300 would probably be best for your considering the budget.
i5-3570K @4.2ghz | Gigabyte Z77-DS3H | 16GB G. Skill Ripjaw 1600mhz 9-9-9-24 (2x8GB) | 120GB Vertex 3/640GB WD 7200RPM | AMD HD7950 @ 1025mhz | 600W Corsair CS600 | Hyper 212 CPU Cooler | 5x 120mm fans 79cfm | Ultra Defender Case
http://pcpartpicker.com/p/19ePh
It goes over budget but if your looking for 2nd hand you should be able to do cheaper..
<p>Mobo - Asus P9X79 LE ----------- CPU - I7 4930K @ 4.4GHz ------ COOLER - Custom Loop ---------- GPU - R9 290X Crossfire ---------- Ram - 8GB Corsair Vengence Pro @ 1866 --- SSD - Samsung 840 Pro 128GB ------ PSU - Corsair AX 860i ----- Case - Corsair 900D
Isn't the cooler a tad too expensive for a budget build?
Here you go: http://pcpartpicker.com/p/19eR5
The 'requirements' don't give much room for variety.
-Asrock 970 extreme4
-amd 6300
-nzxt source 220
-used corsair 4gb ram
-used PNY 660ti
-used corsair cx500
yeah it is but remember he is looking for 2nd hand components so he could save money in other areas...
But still a single 120 rad cooler probably wouldn't even beat a high end air cooler.
Yeah i get that point but i guess it's just what I would go for....
could deal without a modular PSU
As would I, he will go liquid cooling in a year or so (overclock)
It's only $35 after rebate. It was the cheapest psu around that would do the job without an adapter.
