New audio codecs and sound quality
woox
I am having a few problems with the sound quality on my Roccat Kave xtd 5.1 headset (I am using windows 8.1). Would downloading audio codecs improve the quality? If so, which codecs would you suggest I dowbload?
Thanks in advance!
"dowbload" You just made up a new word mate!
cool
But what does it mean?
Audio codecs don't usually help, it's mostly the headphones that are the culprit.
You aren't the woox, are you?
something dirty
How do you know?
sounds like it lol
Getting a BJ when drinking Mountain Dew?
EDIT: We should change it to dewblowed
More interesting would be getting blown by someone who is drinking MD.
To the OP, usually the original recording and your headphones have the biggest impact on sound. If you're listening to 128kbps mp3, you'll want to try to find those songs in at least 192kbps, beyond that there isn't going to be much improvement.
