What would be the best GPU for F@H at the moment. I know the new GTX 900 series do very well but they are quite expensive for me to get where i live. So for PPD per dollar what would be the best card
  1. PPD (purified protein derivative) skin test is a test used to determine if you suffer from tuberculosis (TB). Tuberculosis is a serious infection, usually of the lungs, caused by bacteria called mycobacterium tuberculosi that are spread by breathing air exhaled by an infected person.
i think im might be on a different page
CM Storm Switch Tester MOD (In-Progress) - http://linustechtips.com/main/topic/409147-cm-storm-switch-tester-macro-mod/
       Ammo Can Speaker 02 (Completed) - http://linustechtips.com/main/topic/283826-ammo-can-speakers-02/       A/B Switch V 0.5 (Completed) - http://linustechtips.com/main/topic/362417-ab-switch-v0
     Build 01 - The Life of a Prodigy -  http://linustechtips.com/main/topic/13103-build-01-the-life-of-a-prodigy/             Build 02 - Silent Server 3000 - http://linustechtips.com/main/topic/116670-build-02-silent-server-3000/
https://linustechtips.com/topic/287360-best-ppd-per/#findComment-3902053
Yea just a bit :P PPD is Points Per Day in this area
https://linustechtips.com/topic/287360-best-ppd-per/#findComment-3902246
Hard to say anything as we dont know your local prices...
So plz, tell us models that are in you price range with current price, after model name.
that would help a lot.
GTX 980 $900
GTX 970 $600
GTX 780 is $600
R9 290x $600
R9 280x $ 450
I'm looking for about $500 or below. I've seen some people say getting two cheaper cards will out perform one expensive card for the same price overall. That's what im looking for. Cheaper lower end cards that perform very well for their price
https://linustechtips.com/topic/287360-best-ppd-per/#findComment-3907877
So we dont need to look for how much that system would take power from wall and inglude it to counting...?
Example: My current system(under nick just click it) with i5 4670K, GTX980 SC acx takes 220w from wall on full foulding. Before GTX980 i had HD7970 and the system take like over 300w. (..i may take more correckt reading of HD7970, before i take GTX980 under water..)
EDIT: Heh, Only one card under 500$ on your list...
EDIT2; So is it GTX970 vs. R280??
Edit 3: Oops Speak too soon. GTX980 seam to take 260w on wall meter when foulding 0x15(like now).. on gpu-z its close to 99% of powerconsum with it and 0x17 / 0x18 takes like70% so maybe driver thing ore something with these new cards or something..
https://linustechtips.com/topic/287360-best-ppd-per/#findComment-3908060
My word of advice, just set a budget and get the best card you can for that price. Then fold away... if you blow to much to get a card that gets  a few extra PPD, you will be sadly disappointed when you get a hard WU and your PPD tanks...
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/287360-best-ppd-per/#findComment-3919225
GTX 980 $900
GTX 970 $600
GTX 780 is $600
R9 290x $600
R9 280x $ 450
280X gets about 100-150k ppd on core 17's (1000mhz-1150mhz). a 970 get 50k on core 18's, 75k on core 15's and 250k ppd on core 17's (1380-1480mhz).
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/287360-best-ppd-per/#findComment-3925588
