Hi,
 I recently bought a NZXT Kraken X61 cooler and i plan to mount the rad on top of my enthoo luxe however im not sure if i should mount the intake fans on top of the rad or below the rad.
I currently have 2 intake fans in the front, 2 intake fans on the top and 1 exhaust at the back. I also have 1 fan inside the case cooling my storage.
Help would be greatly appreciated.
Thanks!
https://linustechtips.com/topic/286073-radiator-fans/
it doesnt matter
i think its easier though to install the fans at the bottom of the rad, because if you put them between the rad and case you will need special longer screws that I'm pretty sure the X61 does not come with
https://linustechtips.com/topic/286073-radiator-fans/#findComment-3884814
You should probably mount them on the bottom, so the heat is exhausted out of the case and not onto your other components
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/286073-radiator-fans/#findComment-3884826
Id put them on top and exhaust out , then it's easier to clean off dust
Please quote me or tag me if your trying to talk to me , I might see it through all my other notifications ^_^
the current list of dead cards is as follows 2 evga gtx 980ti acx 2.0 , 1 evga gtx 980 acx 2.0 1600mhz core 2100mhz ram golden chip card ... failed hardcore , 1 290x that caught fire , 1 hd 7950 .
may you all rest in peaces in the giant pc in the sky
https://linustechtips.com/topic/286073-radiator-fans/#findComment-3884839
Sorry but i dont quite get wat u mean. They are going to be intake fans so either way they are going to be blowing hot air from the rad into the case.
https://linustechtips.com/topic/286073-radiator-fans/#findComment-3884842
I, soz I just skimmed over it, I'd put it on the top then
https://linustechtips.com/topic/286073-radiator-fans/#findComment-3884851
True, however id rather have positive air pressure in the case rather than negative
true , then ghetto mount the rad outside the case ? Lmao I almost did that today on my pc
https://linustechtips.com/topic/286073-radiator-fans/#findComment-3884872
xD id love to see that lol
you know what f***k it ima do that tonight now xD , if my hose is long nuff ....
https://linustechtips.com/topic/286073-radiator-fans/#findComment-3884888
HELL YES!!! Be sure to sent me some photos
lmao , will do this is gone be so awful xD ... I just might have too much spare time lol
https://linustechtips.com/topic/286073-radiator-fans/#findComment-3884899
Actually on second thought, dont do that as canada can get rlly cold lol
I was thinking about doing something simmilar , like having like a detachable 480 external rad but idk where I'd put it.
So many ideas so little money and effort
https://linustechtips.com/topic/286073-radiator-fans/#findComment-3884949
lol shove it in the refrigerator
xD I have a chest freezer that might work...
https://linustechtips.com/topic/286073-radiator-fans/#findComment-3884983
