I have come up with this build for my budget of 1200-1300$.
I already have a Power Supply, HDD and SSD from my old build.
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($317.99 @ SuperBiiz)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($89.99 @ Amazon)
Motherboard: MSI Z97-GAMING 7 ATX LGA1150 Motherboard  ($169.79 @ SuperBiiz)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card  ($348.99 @ NCIX US)
Case: Corsair 750D ATX Full Tower Case  ($124.99 @ NCIX US)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($89.98 @ OutletPC)
Total: $1240.72
Generated by PCPartPicker 2015-01-06 02:04 EST-0500
https://linustechtips.com/topic/285456-build-help-opinions-changes-suggestions/
Looks good my friend, but you can get windows for $15 bucks at http://reddit.com/r/microsoftsoftwareswap
Other than that, awesome build!
// irenebb-pc v5 // [] Intel i5-9400F [] Radeon VII Lisa Su Edition [] 24GB Crucial Ballistix [] Acer ED323QUR (1440p/144hz) []
Are you planning on adding a monitor?
Because the ASUS PB238Q is a great monitor and a cheap buy at less than $200.
See here —> http://pcpartpicker.com/part/asus-monitor-pb238q
@ColeTrainX
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
its a good build but drop the H100i and opt for an air cooler
the cooler is nothing but trouble with mounting issues, pump failure and Corsair Link software issues
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
If you're not going to be doing great amounts of multitasking or other things like rendering, you might consider getting an i5-4690k, and then use the money saved from that to get a 780ti (faster but about 100$ more)
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
@Geekazoid: I already have a 27" monitor, but I will be adding this to my wish list for the future. THANK YOU!
@Atmos: I am going to be streaming with this build, so the i7 is preferred.
@dragoon20005: Also, I plan on Overclocking my CPU so water cooling is necessary, what would you recommend since you do not like the Corsair one?
Look at the CoolerMaster Nepton 240M
linked by @Faceman
http://linustechtips.com/main/topic/285404-us-cooler-master-nepton-240m-90/
UPDATE
Total: $1241.72
Generated by PCPartPicker 2015-01-06 02:27 EST-0500\
UPDATED UPDATE:
CPU Cooler: Enermax ELC-LT240-HP 111.0 CFM Liquid CPU Cooler  ($105.77 @ OutletPC)
Total: $1256.50
Generated by PCPartPicker 2015-01-06 02:30 EST-0500
Gotta say what yer planning in yer original post to help clarify things matey. Stuff like "im doing mostly gaming" "im steaming" or "im doing video editing" all those are quite valuable in determining a use for a rig :3
UPDATE
Total: $1241.72
UPDATED UPDATE:
Looks good, but you can get better, and less expensive RAM.  Also, check out the Phanteks Enthoo Luxe or Phanteks Enthoo Pro for your chassis.
PCPartPicker part list: http://pcpartpicker.com/p/J4m6P6
Price breakdown by merchant: http://pcpartpicker.com/p/J4m6P6/by_merchant/
CPU Cooler: Cooler Master Nepton 240M 76.0 CFM Liquid CPU Cooler  ($90.99 @ Newegg) <-- Get this cooler, not the Enermax.
Memory: G.Skill Sniper Series 8GB (2 x 4GB) DDR3-2133 Memory  ($69.99 @ Newegg)
Case: Phanteks Enthoo Luxe ATX Full Tower Case  ($149.99 @ Amazon)
Total: $1237.72
Generated by PCPartPicker 2015-01-06 02:31 EST-0500
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
@Atmos: I apologize, I'm quite new at this whole thing! Thank you for the tips though. :)
ANOTHER UPDATE:
I plan to game and stream with this build. I was also attempting to keep to a strict Corsair/MSI and Red/Black build.
ANOTHER UPDATE:
perfect info there mate, can go a long way to help people figure out what might be better. And if it comes down to it and the GPU you want has a different colored shroud than what you're planning on building, you can always check out linus' vid on how to repaint cpu cooler shrouds to make them more pretty. Tek Syndicate also did a good job in showing how you can do that as well w/ slightly different finer paint.
@Atmos: My GPU is red and black I thought.
That it is, at least there might be others out there w/ slightly better performance, not sure on pricing though as the higher end models can get more expensive.
@Atmos: That may be true, this one was highly recommended though for the price and performance.
UPDATE:
Total: $1256.50
Generated by PCPartPicker 2015-01-06 02:45 EST-0500
