The card i am thinking about getting Sapphire Radeon R9 290X Vapor-X OC 8192MB GDDR5
Link http://www.overclockers.co.uk/showproduct.php?prodid=GX-353-SP
My first question. Is this card the Sapphire Radeon R9 290X Vapor-X OC 4096MB  Better than the stranded R9 290x the reference card as i had that before in terms of playing games will i get a better fps.
And my second question should i get this card as the 4gb gddr5 version or the 8gb gddr5 version will i notice a diffrence with 4 more gigs of ram in games or is that only for people who do video editing.
My Monitor is 1920x1080 and is 144hz i will not be playing any game about 1920x1080
https://linustechtips.com/topic/284570-two-questions-about-this-gpu-please-help/
For comparing different models, check the benchmarks p, especially the gaming ones as they're easier to visualize. And if you can afford it take the extra 4GB as it will last so much longer and I imaging there will be a definite increase in performance and also if you do any productivity work. You might want to google this first though.
It Won't Fail Cause of Me.
Sadly i looked and could not find anym
That card has a pretty high stock oc, thats about it... You could probably oc another card to the same specs if you really wanted to
And take the extra 4gb for "futureproofing" purposes
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
The gaming performance of a card will be mostly determined by the GPU it has, in this case it's a R9-290X. Pretty much all R9-290Xs will perform roughly the same because they all use the same chip.. The aftermarket cards may allow you to overclock it a bit farther which will improve performance, but it's always still going to perform like an R9-290X.
Having more VRAM will only affect performance if 4 GB of VRAM is too little. At the moment, the only thing in which having that much VRAM will actually affect performance is if you're gaming at very very high resolutions. If you're not using a 4K monitor, chances are that an 8 GB card will perform exactly the same as a 4 GB card.
i7 not perfectly stable at 4.4.. #firstworldproblems
You will save money on a power supply and drop some of the heat with a 970. don't get a 290x
970 does not yet have a 8 gb card
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
He doesn't need 8gb if he is running at 1080p. Core speeds are going to matter more at that resolution. 970 most likely won't have 8gb versions because the bus is too small. 256-bit is IMO too small as it is to be considered high end.
Will a 970 play most games maxed out at 60fps or more though? Will i get a better fps in games than the r9 290x?
The 8GB is so much more money. It seems like textbook throwing money down the drain for future proofing. I'd go with a 4GB R9 290x. It's a monster of a card that will absolutely crush 1080p. Hopefully 4GB will become a lasting highend standard for a few years.
They're neck and neck. You can't go wrong either way.
http://www.anandtech.com/bench/product/1355?vs=1056
One thing to note is this is comparing the best factory overclocked GTX 970 to the absolute worst R9 290x (the reference model).
