I found a Maxtor one touch 160gb hard drive http://www.cnet.com/products/maxtor-onetouch-160gb/
Is it worth doing anything with?
https://linustechtips.com/topic/282859-found-old-external-hard-drive/
Store stuff, take it with you to work/school or whatever
It's like really big. Like bigger than a 5.25 inch drive
i have like 3 of thoes. their solid metal construction make them a pain to carry there so heavy
Yeah
use it as a backup drive.
For what? Its only 160gb
Well, just use it as a backup drive. for some important stuff.
Harvest the platter(s) and use them as coasters?
That time I saved Linus' WiFi pass from appearing on YouTube:
A sudden Linus re-appears : http://linustechtips.com/main/topic/390793-important-dailymotion-account-still-active/
Damn, I've one of those. Not sure what size it is, might be 300gb or 160gb. Heavy as two bricks and the size of an optical drive at least.
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
fir files! surely you have random folders that could use a backup copy. you obviously won'y be able to back up an entire drive, but for key files it would be perfect.
Recovering Apple addict
ASUS Zephyrus G14 2022
CPU: AMD Ryzen 9 6900HS GPU: AMD r680M / RX 6700S RAM: 16GB DDR5
