help choosing a gpu
Go to solution Solved by minibois,
750 Ti or R9 270(X)
@renzar501 don't forget to follow your topics
hi i am new to the whole computer building and i was wondering what is the best gpu for a price of £130. it has to be able to be sli or crossfire capable and at least 2gb gddr5 of ram. also one has to be able to run bf4 on one monitor in 1080p on high with 48-50+ fps. if you can help me many thank  :)
from renzar501
https://linustechtips.com/topic/281371-help-choosing-a-gpu/
750 Ti or R9 270(X)
https://linustechtips.com/topic/281371-help-choosing-a-gpu/#findComment-3820129
For £15 over budget - http://uk.pcpartpicker.com/part/gigabyte-video-card-gvr928wf3oc3gd
And I really don't recommend going for an R9 270 (x)
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/281371-help-choosing-a-gpu/#findComment-3820130
I'd check out cards like the GTX760 or GTX750Ti from Nvidia, or the R7 260x / R9 270 for that price point, you could also consider going for a used GPU.
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
https://linustechtips.com/topic/281371-help-choosing-a-gpu/#findComment-3820131
https://linustechtips.com/topic/281371-help-choosing-a-gpu/#findComment-3820168
i think that is the choice but could i run for a bit with one card and then add another
Yes you can, the R9 280 can max out BF4 with 60+ fps
https://linustechtips.com/topic/281371-help-choosing-a-gpu/#findComment-3820258
Yes you can, the R9 280 can max out BF4 wibut it would be better to get 2 270x right
2x R9 280 > 2x R9 270X
https://linustechtips.com/topic/281371-help-choosing-a-gpu/#findComment-3820345
750 Ti or R9 270(X)
@renzar501
Also just a note, the 750Ti cannot SLI
https://linustechtips.com/topic/281371-help-choosing-a-gpu/#findComment-3820356
the 750ti cannot support sli
@renzar501
Oh, you're right. My brain immediately saw 1080p gaming, ~50 FPS 2 GB GDDR5 with a price tag of ~130 pounds, so I said 750 Ti..
I still think a 270 or 270X is really good, or a 280 if you can stretch your budget a little further.
https://linustechtips.com/topic/281371-help-choosing-a-gpu/#findComment-3820443
Which card?
https://linustechtips.com/topic/281371-help-choosing-a-gpu/#findComment-3827393
