Do I need any fans?
By
Doctorfrozo
in Cooling
in Cooling
Solved by Pelop17,
Hello LTT forums!
Is there anything i need to worry about (or buy) air cooling wise having to do with this build? http://pcpartpicker.com/user/DoctorFrozo/saved/ztP9TW
If so, what do i need to do?
Thanks!
No you are fine because your gpu has a good cooling solution and you have a cpu cooler also,
I imagine if so you have pretty decent case fans
Featured Topics
Bkstrat ·
Posted in Troubleshooting0 -
2
remo233 ·
Posted in Power Supplies3 -
2
3
VioletGiraffe ·
PietervdWiel ·
Posted in New Builds and Planning7 -
9
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
