So I want to build my own pc and someone recommended this http://uk.pcpartpicker.com/p/fWBsjX
I want to game but also rendering!! So is this good, if not what can I change but my budget is 600 euros/dollars
I want to change the cpu to a better one but then I don´t stay in my budget
help!!
Akkus Kursat
https://linustechtips.com/topic/280497-pc-build-help/
CPU: AMD FX-6300 3.5GHz 6-Core Processor  (€89.90 @ Caseking)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (€34.83 @ Amazon Deutschland)
Motherboard: ASRock 970 Extreme3 ATX AM3+ Motherboard  (€76.50 @ Amazon Deutschland)
Memory: Kingston Fury Black Series 8GB (1 x 8GB) DDR3-1866 Memory  (€72.90 @ Amazon Deutschland)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  (€53.29 @ Amazon Deutschland)
Video Card: Gigabyte Radeon R9 280 3GB WINDFORCE Video Card  (€206.43 @ Amazon Deutschland)
Case: NZXT Source 210 Elite (Black) ATX Mid Tower Case  (€49.90 @ Caseking)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  (€64.07 @ Amazon Deutschland)
Total: €647.82
Generated by PCPartPicker 2014-12-30 15:10 CET+0100
https://linustechtips.com/topic/280497-pc-build-help/#findComment-3808581
Would the CPU be good for rendering (photoshop, after effects, sony vegas,...? and also I would like to have nvidia instead of AMD
What type of things are you rendering?
You need to quote a post or tag a member or else they won't get a notification you replied to them.
That's more expensive and worse than the original list.
https://linustechtips.com/topic/280497-pc-build-help/#findComment-3808585
I would say this is a pretty good pc.
Why would you want a better CPU? The Intel Core i5-4430 is a really good CPU.
I have the i5-4670 which is awesome, but would cost ~25 more.
and I have just noticed that the Motherboard doesn´t support usb 3.0. But I need usb 3.0 so maybe that can be change
Akkus Kursat
https://linustechtips.com/topic/280497-pc-build-help/#findComment-3808596
I would like to render After effects, sont vegas,... (video and photo)
Akkus Kursat
https://linustechtips.com/topic/280497-pc-build-help/#findComment-3808642
The CPU is definitly not bad for rendering. But of course not great. It's decent and gets the job done. I cant remember correctly how long it would take to render a video on my i5, but it was definitly okay.
If you need USB3 and maybe a different CPU for rendering anyway, then an AMD CPU could be a good choice. But pls don't ask me anything about AMD. I'm more of an intel guy :P
You might even save enough money by purchasing an AMD CPU, so you could buy a NVidia card if you really want one.
https://linustechtips.com/topic/280497-pc-build-help/#findComment-3808688
me to (never liked AMD)
and thank you for the information  :)
Akkus Kursat
https://linustechtips.com/topic/280497-pc-build-help/#findComment-3808872
what about the i5-4690k
Akkus Kursat
https://linustechtips.com/topic/280497-pc-build-help/#findComment-3808917
I guess you won't see much difference between an i5 4670 and an i5 4690k.
http://www.cpubenchmark.net/compare.php?cmp[]=2284&cmp[]=1933&cmp[]=1924
http://uk.pcpartpicker.com/p/nnVXdC I like this one more another motherboard and a decent cpu
Akkus Kursat
https://linustechtips.com/topic/280497-pc-build-help/#findComment-3809029
I meant the type of content you're rendering.
Simply cutting video clips together is very different from dropping buckets of Red giant plugins on many layers
https://linustechtips.com/topic/280497-pc-build-help/#findComment-3815825
https://linustechtips.com/topic/280497-pc-build-help/#findComment-3837258
