whats there to say about it besides that its overpriced, stupid, and a waste of money?
https://linustechtips.com/topic/278732-linus-tech/#findComment-3777398
https://linustechtips.com/topic/278732-linus-tech/#findComment-3777399
AFAIK an eGPU enclosure + GPU costs close to a full gaming rig. An eGPU enclosure is a case, power supply, and thunderbolt-capable motherboard after all. Add in a GPU and that's practically a full gaming in itself, and wil cost close to one.
https://linustechtips.com/topic/278732-linus-tech/#findComment-3777406
I like my setup for the portability. I am not home enough to justify a full blown tower, and like having my laptop on the go, with a gaming machine waiting at home,
https://linustechtips.com/topic/278732-linus-tech/#findComment-3777415
What is "eGPU"? Since I don't know what it is, I know I would appreciate a video on it.
https://linustechtips.com/topic/278732-linus-tech/#findComment-3778439
I think Linus Tech should do a video on eGPU for some people who have laptops and can't afford to build a gaming pc or just want a portable gaming rig. What do you guys think about this?
@LinusTech @Slick @nicklmg
He did make one
I believe he means economic. As in cheap GPU.
EDIT: Nevermind, it means external. Disregarddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddd
Edited by fallout68
https://linustechtips.com/topic/278732-linus-tech/#findComment-3778479
THIS. NOW. WHERE THE FUCK IS IT LINUS?!?!?! HUH?!?!?!
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
https://linustechtips.com/topic/278732-linus-tech/#findComment-3778528
He did one at the start of last year but there wasn't really any driver support at the time.
CPU: i7 5820K 4.0GHz @1.15V | MOBO: Asus X99 Sabertooth | GPU: Gigabyte Windforce GTX 980Ti, LTT Orange | CASE: NZXT H440 Black 2015 | COOLER: Noctua NH-D15S w/ LTT Fans | RAM: 32GB Patriot 3000MHz | STORAGE: 512GB Samsung 950 Pro, 960GB Sandisk Ultra II 3 x 8TB Seagate HDD's | PSU: 750W Seasonic X series, black / orange cablemod cables| Monitors: 3x Asus VX24AH's | AUDIO OUT: Microlab SOLO 8C, Sennheiser HD 650's, Audio engine D1 Amp / DAC | AUDIO IN: Blue Snowball | Keyboard: CM Storm QuickFire TK MX Green | Mouse: Logitech G900 Proteus Spectrum + RSI Extended Mouse Pad | PCPP Linkhttp://nz.pcpartpicker.com/list/hPjFd6
https://linustechtips.com/topic/278732-linus-tech/#findComment-3778606
