Hey guys,
I have R9 290x twin frozr card. I can not run card on uber mode. Whenever uber mode is enabled, PC won't boot. Card runs perfectly in quiet mode. Any solutions???
And also, my maximum fan speed is about 3000rpm, is there any way to increase this?
Note - A paper in Graphic card package says, it's a switch for hybrid bios and legacy bios
My motherboard is intel DH77EB (pretty low end)
http://www.intel.com/content/www/us/en/motherboards/desktop-motherboards/desktop-board-dh77eb.html
https://linustechtips.com/topic/277609-290x-uber-and-quiet-switch/
I don't believe that the switch is for Uber mode. It's to switch between the Hybrid and Legacy BIOS as you already mentioned.
on msi's card, its a bios switch.
Personal Rig v3: AMD Ryzen 7 2700X | Noctua NH-U14S | Gigabyte B450 Aorus Pro ITX | Zotac GTX 2070 8GB | 16GB G-Skill Trident DDR4 3200MHz | EVGA Supernova 750B | Phanteks Enthoo Evolv ITX
Peripherals: Sennheiser HD518 & Classic ModMic | Corsair K65 Luxe | Zowie EC2 | ASUS VG259QM  |  ASUS VG278E | Klipsch ProMedia 2.1
Uber mode? Msi should consider naming their OC mode to this... Hahaha
It's the name AMD specified to the OC mode on their cards.
Alright, then is there any way to increase the fan speed beyond 3000 rpm??
Sorry have not seen anyone doing that.
i5 2400 | ASUS RTX 4090 TUF OC | Seasonic 1200W Prime Gold | WD Green 120gb | WD Blue 1tb | some ram | a random case
why on earth would you want to? if you really need lower temps, improve airflow... that'll do you much more good than fan speeds
CPU: Intel i7 4770k w/Noctua NH-D15, Motherboard: Gigabyte Z97 Ultra Durable, RAM: Patriot 8Gb 1600Mhz (2x4Gb), GPU: MSI R9 390x Gaming,
SSD: Samsung 840 EVO 1Tb, HDD: Caviar Black 1Tb, Seagate 4Tb Hybrid, Case: Fractal Design Define R4, PSU: Antec Earthwatts 750w
Phone: LG G2 32Gb Black (Verizon) Laptop: Fujitsu Lifebook E754 w/ 1TB Samsung 840 Evo SSD Vehicle: 2012 Nissan Xterra named Rocky
Its a BIOS switch, MSI have some software with some presets that u can switch to
Current Rig:   CPU: AMD 1950X @4Ghz. Cooler: Enermax Liqtech TR4 360. Motherboard:Asus Zenith Extreme. RAM: 8GB Crucial DDR4 3666. GPU: Reference GTX 970  SSD: 250GB Samsung 970 EVO.  HDD: Seagate Barracuda 7200.14 2TB. Case: Phanteks Enthoo Pro. PSU: Corsair RM1000X. OS: Windows 10 Pro UEFI mode  (installed on SSD)
Peripherals:  Display: Acer XB272 1080p 240Hz G Sync Keyboard: Corsair K95 RGB Brown Mouse: Logitech G502 RGB Headhet: Roccat XTD 5.1 analogue
Daily Devices:Sony Xperia XZ1 Compact and 128GB iPad Pro
