h100i pump and rad fans on full blast?
Solved by Wingfan,
OK i have a splitter and will put them together for sure. check my post above with the link to the manual for this board. now im wondering if i even plugged the cooler in properly...
I dont think it will matter which USB you plug into. Awsome you have a splitter, makes it easier. The pump should be CPU_fan, and the fans in CPU_OPT.
Featured Topics
Sirin ·
Posted in Storage Devices0 -
Nicktheflick ·
Posted in CPUs, Motherboards, and Memory6 -
7
creat0r ·
Posted in Programming2 -
Rakeboy77 ·
Posted in Troubleshooting4 -
1
4
5
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
