So...I am reading all of these people putting 1.3 to 1.4 volts into these haswell e processors and being stable.
I have a kracken x61 running at normal temps that average anywhere from 29c to 32c under idle and 60 to 65 under load at 1.19 volts 4.2 ghz oc.
I really want to push for 4.4 or 4.5
You most likely get tired of hearing this by now but is it safe from a life span point of view?
get rekt
Gamer and enthusiast. Rig: 5930k @ 4.2 ghz, EVGA GTX970 SC, 16gb ram @3200 and all the noctua fans a man could want.
https://linustechtips.com/topic/272030-voltage-question-x99/
yup
as long as the temps are within reason (below 85C) your CPU will last 10+ years easily
https://linustechtips.com/topic/272030-voltage-question-x99/#findComment-3690407
yup
Just asking because this is my first propper oc. I did another one but my i7 920 didn't handle much over 1.25 very well.
get rekt
https://linustechtips.com/topic/272030-voltage-question-x99/#findComment-3690418
yup
probably but you know that HIS CPU is hotter then the programs show it. the cooler only catches up the cooled temp. what is coming from the the CPU cores is maybe 5-6 celcius hotter.
Btw OP. it is not the volts who kills your CPU. it the temps. you can have 1.9 volts at low temp and it would be fine. but expect 300 celcius on idle:D
[spoiler= Dream machine (There is also a buildlog)]
Case: Phanteks Enthoo Luxe - CPU: I7 5820k @4.4 ghz 1.225vcore - GPU: 2x Asus GTX 970 Strix edition - Mainboard: Asus X99-S - RAM: HyperX predator 4x4 2133 mhz - HDD: Seagate barracuda 2 TB 7200 rpm - SSD: Samsung 850 EVO 500 GB SSD - PSU: Corsair HX1000i - Case fans: 3x Noctua PPC 140mm - Radiator fans: 3x Noctua PPC 120 mm - CPU cooler: Fractal design Kelvin S36 together with Noctua PPCs - Keyboard: Corsair K70 RGB Cherry gaming keyboard - mouse: Steelseries sensei raw - Headset: Kingston HyperX Cloud Build Log
https://linustechtips.com/topic/272030-voltage-question-x99/#findComment-3690719
real temp gt is fairly accurate.
get rekt
https://linustechtips.com/topic/272030-voltage-question-x99/#findComment-3691937
