prime95 on i7 , way too hot for my cpu?
Solved by vlkn´,
that right , he is pissed i got gtx 970 g1 with i7 4790k and he has i5 4690k with r9 280x.
so i dont need to run the prime and my temp are alright ? i get max 67 c playing ac unity on ultra + msaa 4x
No, you won´t ever need to run prime95 if you use this cpu @stock speed (no overclock)
Edit: Temps are fine.
Featured Topics
VioletGiraffe ·
PietervdWiel ·
Posted in New Builds and Planning3 -
4
DaveNoir ·
Posted in Troubleshooting0 -
PietervdWiel ·
5
4
floris.rodedio ·
Posted in CPUs, Motherboards, and Memory1
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
