I'm either getting msi 970 or asus strix 970. But how probable am I gonna get a coil whine?
And since I'm buying mine at frys, if I do get coil whine, can I just return it to frys or do I have to call asus or msi? Is there a way to fix it? Which brand am I more less likely to get it and have no problem or issues? Please don't suggest g1 , I was originally gonna get it but it's out of stock and performance difference aren't that far apart anyway especially since I'll do sli in the future.
https://linustechtips.com/topic/270663-coil-whine-issue/
Most retailers or manufacturers will not honor the warranty should you get coil whine(at least for that issue). There is no way to really fix it.
https://linustechtips.com/topic/270663-coil-whine-issue/#findComment-3672590
Limit your fps in games that are easy to run and have no fps caps on them, the gpu will be working it's ass off for those 10000 useless frames when you don't need them and that causes coil whine.
~Just the tips
 The only good human being is a dead human being.
I5 4690K MSI GTX 970 GAMING 4G MSI Z97 GAMING 5 G.SKILL RIPJAWS X 2X8GB 1600MHZ CL10 CORSAIR CX750M CRUCIAL MX100 512GB 2X WD BLUE 1TB CORSAIR 300R BENQ RL2455HM ♦ WIN 8.1 PRO ♦ UBUNTU 14.04
https://linustechtips.com/topic/270663-coil-whine-issue/#findComment-3672627
Why do people rma it?
If the retailer or manufacturer accepts it, then it's to attempt to get rid of it with another version of the same product.
https://linustechtips.com/topic/270663-coil-whine-issue/#findComment-3672633
There is about a 15% chance of you getting coil-whine.
It's not too common but you can return it in most cases if you purchase that extra
exchange no-questions-asked extended warranty that I always say no too at NCIX.
blackshades on
https://linustechtips.com/topic/270663-coil-whine-issue/#findComment-3672635
Or it doesn't matter if I get asus or msi, both can and have the equal chance of me getting coil whine ?
If that case, which is better and looks and performance better? Msi or asus
AFAIK, they perform about the same. What looks better is highly subjective.
https://linustechtips.com/topic/270663-coil-whine-issue/#findComment-3672672
All cards can have coilwhine nothing you can do about it however you can make it less by using a good quality psu.
I would go for the Asus.
https://linustechtips.com/topic/270663-coil-whine-issue/#findComment-3672681
Gigabyte G1 is best out of all of them.
CPU: i7 5820k @4.4GHz | MoboMSI MPower X99A | RAM: 16GB DDR4 Quad Channel Corsair LP | GPU: EVGA 1080 FTW Case: Define R5 Black Window | OS: Win 10 Pro
Storage: SanDisk Ultra II 960GB 2x WD Red 4TB | PSU: EVGA 750W G2 | Display:Acer XF270HU + Dell U2515H | Cooling: Phanteks PH-TC14PE
Keyboard: Ducky One  TKL Browns | Mouse: Steel Series Rival 300 | Sound: DT990s
https://linustechtips.com/topic/270663-coil-whine-issue/#findComment-3673452
2 gigabite g1 970's that i got both had coil whine under any load, doesnt matter if its 10 or 10000 fps, and its not the psu, tested it on several systems
Hey there. You are looking mighty fine today, have my virtual cookie!  :ph34r:
MY RIG: http://linustechtips.com/main/topic/34911-my-setup-gold-ghetto-gg-lots-of-pictures/#entry446883
https://linustechtips.com/topic/270663-coil-whine-issue/#findComment-3673464
Turn on V-sync. Coil whine can not be fixed permanently.
V-Sync is not a permanent fix.
https://linustechtips.com/topic/270663-coil-whine-issue/#findComment-3673841
I've got a Gigabyte GTX 970 G1 gaming, and even with a full overclock and under full load from the stress tester, I notice no coil wine at all. (It may be there, but if I can't hear its good, and there are headphones for a reason)
           .;ldkO0000Okdl;.                michael@SUSE-BlackBox
        .;d00xl:^''''''^:ok00d;.            OS: openSUSE 20260405
      .d00l'                'o00d.          Kernel: x86_64 Linux 6.19.11-1-default
    .d0K^'  Okxoc;:,.          ^O0d.        Uptime: 2d 21h 52m
   .OVVAK0kOKKKKKKKKKKOxo:,      lKO.       Packages: 6556
  ,0VVAKKKKKKKKKKKKK0P^,,,^dx:    ;00,      Shell: bash 5.3.9
 .OVVAKKKKKKKKKKKKKk'.oOPPb.'0k.   cKO.     Resolution: 3840x1080
 :KVAKKKKKKKKKKKKKK: kKx..dd lKd   'OK:     DE: KDE
 lKlKKKKKKKKKOx0KKKd ^0KKKO' kKKc   lKl     WM: KWin
 lKlKKKKKKKKKK;.;oOKx,..^..;kKKK0.  lKl     GTK Theme: Breeze-Dark [GTK2], Breeze [GTK3]
 :KAlKKKKKKKKK0o;...^cdxxOK0O/^^'  .0K:     Icon Theme: breeze-dark
  kKAVKKKKKKKKKKKK0x;,,......,;od  lKP      Disk: 13T / 22T (60%)
  '0KAVKKKKKKKKKKKKKKKKKK00KKOo^  c00'      CPU: AMD Ryzen 7 5800X3D 8-Core @ 16x 4.55295GHz
   'kKAVOxddxkOO00000Okxoc;''   .dKV'       GPU: AMD Radeon RX 6700 XT (radeonsi, navi22, ACO, DRM 3.64, 6.19.11-1-default)
     l0Ko.                    .c00l'        RAM: 13127MiB / 48094MiB
      'l0Kk:.              .;xK0l'
         'lkK0xc;:,,,,:;odO0kl'
             '^:ldxkkkkxdl:^'
https://linustechtips.com/topic/270663-coil-whine-issue/#findComment-3675234
