Okay,
I've been debating on what case to get, between the Enthoo Pro (for it's price, performance, looks but may not be going with it for terrible window) and the Corsair 760T (looks, performance, everything but it's pricey). I'm inching more towards the 760T as I might just be able to squeeze it in.
So, what I'm wanting to do is setup some lights inside to make it look good. So if anyone has any idea on how I can do this with LED strips and how I can set this up and if they know any good ones to get, that would be awesome!
Please reply with advice (either LEDs or
Thanks,
https://linustechtips.com/topic/269889-led-strips/
-SNIP-
As for windows on the Enthroo Pro if you are worried about scratching it up over time you can always replace it for glass in the future if you ever have problems with it.
But about LED's Bitfenix Alchemy are the most popular usually, Icemodz, or Darksides are also alternative and are both excellent, if you want to do it on a budget and don't mind some DIY work I do recommend getting a roll of SMD5050 LED's online and cutting your own lengths and connecting them to power.
https://linustechtips.com/topic/269889-led-strips/#findComment-3663147
Bitfenix Alchemy LED strips, or the NZXT Hue if you want RGB.
https://linustechtips.com/topic/269889-led-strips/#findComment-3663151
Okay,
Thanks,
Get strips and a controller off ebay from china.
Same strips as are sold for tons more anywhere else, but you have to wait for shipping.
I used some in about 5 builds, work perfect and havent failed in 4+ years.
D3SL91 | Ethan | Gaming+Work System | NAS System | Photo: Nikon D750 + D5200
https://linustechtips.com/topic/269889-led-strips/#findComment-3663156
Thanks for the advice, and what would I plug the LEDs into?
https://linustechtips.com/topic/269889-led-strips/#findComment-3663162
Got links to these places? Where would I plug the controller and all into?
https://linustechtips.com/topic/269889-led-strips/#findComment-3663166
Depending on the LED if you get RGB ones you will need a controller and a roll of LED's like theses:
http://www.amazon.com/SUPERNIGHT-Waterproof-300LEDs-Flexible-Controller/dp/B00B2F3KDQ/ref=sr_1_3?ie=UTF8&qid=1418542474&sr=8-3&keywords=smd+5050
If you plan to stick with single colors you can directly connect the LED strip to 12V into a molex via an adapter or soldering them to the LED strips:
http://www.amazon.com/SUPERNIGHT-White-16-4FT-Flexible-Lights/dp/B00ASVGI8O/ref=sr_1_8?ie=UTF8&qid=1418542474&sr=8-8&keywords=smd+5050
https://linustechtips.com/topic/269889-led-strips/#findComment-3663227
For the RGB lights do you still need to connect to a molex? It seems complicated now o_o
https://linustechtips.com/topic/269889-led-strips/#findComment-3663260
Yes they will also connect to 12V but through the controller first to let you set the colors and different modes, as for the connector they usually use a small 2.1mm DC jack. You can either crimp on a molex or get something like a 2.1mm to molex adapter.
https://linustechtips.com/topic/269889-led-strips/#findComment-3663291
ugh, sounds super complicated now... :(
https://linustechtips.com/topic/269889-led-strips/#findComment-3663304
The pre-made strips may be a bit easier for you if you aren't very familiar with how to wire it, Icemodz has a kit that is pre-made and others such as NZXT also have RGB kits.
https://linustechtips.com/topic/269889-led-strips/#findComment-3663450
