Hi, I just installed my new FX 8350 and played some BF4, the fan started to spin really fast making it very loud, then I opened CAM and my CPU was at 70-73°C, is that normal? Im using the stock heatsink, but one thing, for some reason the stock hetasink it came with doesnt have the AMD sticker on the center of the fan and on the sides it says "cooler master" could this be the issue? maybe its not the "original heatsink" and thats casung problems? Im running my cpu at stock speeds, no overclock, thanks for your help!
https://linustechtips.com/topic/268903-fx-8350-overhetaing-issues/
Can you give us a photo? Where roughly are you located? What us the rough temp in your room?
When i had the stock cooler on my 8320 over the summer (no A.C.) my chip was getting really hot.
EDIT: what case/fans do you have?
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
Cooler master is the stock heatsink OEM.
That is a bit of a problem, and the stock coolers don't do a very good job. The chip can survive at that temperature, but not for too long. Get a new cooler asap.
Generally accepted temperatures are 70c for benchmarking/stress test only, 65c for short term stresses, and 62c or lower for 24/7 operation.
Okay, I can not give you a photo because for some reasom cam doesnt want to open anymore, I live in Mexico and the "average" temperature in winter is like 17-20°C, probably in my room the temp is 25°C maybe beacuse of the PC, my case is an NZXT Phantom 410 it only has the three fans it comes with. My motherboard is also new and its a Gigabye 970A-UD3P. Any aftermarkets heatsink you recommend?
Hyper 212 EVO
I3-4150 | Be Quiet! Dark Rock Pro 3 | 8GB KINGSTON FURY RAM | MSI Z97-G43 | HYPERX FURY 120GB SSD SAPPHIRE HD7950 VAPOR-X | Phanteks Enthoo Pro M | EVGA 500W | Corsair SP120's w/ NZXT Fan Hub
Plans: I5-4690K || EVGA GS 650W | KINGSTON FURY 8GB RAM  PCPARTPICKER: https://uk.pcpartpicker.com/
Yeah, that's pretty normal for the stock heatsink.
A good enough one that is stupid cheap would be the Cooler Master Hyper TX3, but the Cooler Master Hyper 212 EVO is definetly better.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
62 is the max! dont let it run past that for long periods of time. You need better cooling.
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
Have a FX 8370 + 212 Evo here, max temp on games like BF4 around 50C. The highest ive ever seen it is 62C on Beamng Drive, which if you didn't know is a very realistic soft body physics game. So its very CPU intensive.
But thats the max/peak recorded temp anyway, its not a clear indication of how the CPU is doing overall.
Stock cooler is OK, but not long term, a 212 Evo will do great in your system.
As a matter of fact why don't they just not include one and make the CPU cheaper for the consumer?
Project Cobalt:
CPU: AMD FX 8370 Motherboard:
Asus M5A97 R2.0
RAM: G.Skill Ares 16GB (2x8GB) DDR3 2133 GPU:
Gigabyte GTX 970 G1 Gaming Case: NZXT H440 (Blue)
Storage: Samsung 840 EVO 256GB +  2x 1TB WD Cavier Blue
PSU: Corsair 750G2
CPU Cooler: Swiftech H220X
Keyboard: Model M + a lot of others
Vintage Gaming PC: AMD Athlon T-Bird 800Mhz, Gainward nVidia Ti200 128MB, 512MB Crucial RAM DDR, Compaq ASPEN 2 OEM Board, Soundblaster Live! 5.1, Windows 98SE
you do need an aftermarket heatsink for those AMD monster man.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
