Best thermal compund?
MX-4 or NT-H1
https://linustechtips.com/topic/267286-best-thermal-compund/#findComment-3630235
IC-Diamond
Wasn't IC-Diamond eating peoples CPUS or something? Or is that old news?  :huh:
Build
Mobo: MSI B550 MAG Tomahawk  ||||| Ram: 32 GB GSkill Trident Z RGB ||||| CPU: Ryzen 5800X ||||| GPU: ASUS RTX 3080 TUF OC ||||| Mouse: Logitech G502 ||||| Headset: Sony WH1000XM3 ||||| Keyboard: Logitech G810 Orion Spectrum ||||| Monitors: Acer XG270HU & LG UltraGear 34GP83A-B ||||| AudioStuff: ONKYO DAC HA200 / Audio Techinca ath-ad900x / MXL TEMPO KR USB Condenser Microphone ||||| Storage: 4 TB WD Black --- 2 TB WD Red --- Toshiba 258 GB M.2  ||||| Custom Loop -  Radiators: 3x360 Rad ||||| Case: LianLi O11d XL Black ||||| PSU: Seasonic X series GOLD 1250w
Laptop: Dell XPS 15 9570 4k With a Logitech MX Master
https://linustechtips.com/topic/267286-best-thermal-compund/#findComment-3630944
Why not GC-Extreme? Its tops other pastes and its cheap.
http://www.tomshardware.com/reviews/thermal-paste-performance-benchmark,3616-18.html
60FPS Microwave
Intel Core i5-4670K | Galax GTX 970 EXOC | ASRock Z97E-ITX/ac | Team Elite 8GB 1600MHz | Gelid Black Edition | Samsung slowdown + WD Blue 1TB x2 | Cooler Master V550 | Corsair K65 + Logitech G100s | MasterCase Pro 3
https://linustechtips.com/topic/267286-best-thermal-compund/#findComment-3631006
It still leaves marks but I've never seen damage worse than a bit of scratching.
https://linustechtips.com/topic/267286-best-thermal-compund/#findComment-3631008
Coolabratory Liquid Ultra, it's expensive, and can be hard to find depending on where you live. But there is nothing that beats it.
Higher is better right???
::Heads to the store, buys extra white extra minty toothpaste::
D3SL91 | Ethan | Gaming+Work System | NAS System | Photo: Nikon D750 + D5200
https://linustechtips.com/topic/267286-best-thermal-compund/#findComment-3631273
Well, thank you for that chart.  I'm kind of a celsius freak and seeing that there is a better thermal paste to the MX-4.. I now know what I must buy in bulk >_>
https://linustechtips.com/topic/267286-best-thermal-compund/#findComment-3631449
Just make sure you get Ultra and not Pro. Pro is pretty much non-removable. Ultra performs more or less the same, but is removable. Also... it is conductive... so be careful applying it, and you have to pre-spread it with a brush too.
https://linustechtips.com/topic/267286-best-thermal-compund/#findComment-3631465
Really?  Pre-spread, huh?  That means being -really- meticulous, but that's fine if it offers better performance.  ^^  Thank you kindly.  So, probably a grain of rice amount and then spread it all around with a tiny brush.  *Nod*
https://linustechtips.com/topic/267286-best-thermal-compund/#findComment-3631473
The tests by which they get these temperatures are very subjective and look at the difference in temps. Its REALLY not worth the effort any money changing the thermal paste for a 2'c difference. considering that for you it might not even cause any change in temps.
Also don't spread thermal comp, especially with a brush, firstly the bristles might come off the bush which will be a pain picking them out the thermal comp.
secondly, spreading the paste causes small air bubbles in the compound which can affect temps (not by much, but it can).
Basically, don't spread the compound yourself, its unnecessary and daft.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/267286-best-thermal-compund/#findComment-3633482
This is true for most thermal compound, but we weren't talking about most thermal compound. We were talking about Coolabratory Liquid Metal Ultra specifically. It is standard procedure suggested by the manufacturer to pre-spread this TIM because it will not spread out properly under pressure from a heat sink as it has a much higher viscosity than most TIMs. It is literally a metal alloy that is liquid at room temperature, it doesn't spread easily.
http://www.coollaboratory.com/en/products/liquid-ultra/
https://linustechtips.com/topic/267286-best-thermal-compund/#findComment-3633616
I use CG-extreme. They sell it in a ten gram container for $30. The container looks like something lip balm would come in. I just hope no one mistakes it for lop balm.. lol
Its good because I was tired of always having to order thermal compound when those little syringes run out. Ten grams lasts awhile.
𝘛𝘳𝘶𝘴𝘵 𝘺𝘰𝘶𝘳 𝘪𝘯𝘵𝘶𝘪𝘵𝘪𝘰𝘯
PC: ibuypower pre-built RDY Y70
Cpu: i9 14900K  Gpu: Zotac 4070 super ti  Ram: 32Gb DDR5  SSD: 2Tb
Case: HYTE Y70  MB: MSI 790-P wifi
Cooling: ibuypower 360mm RGB aio
Laptop: Lenovo Legion Pro 5i, u9 275HX, 32gb ddr5, 5070ti, 1tb SSD, 16" 165hz oled
https://linustechtips.com/topic/267286-best-thermal-compund/#findComment-3634427
If I'm not mistaken Coolabratory is also corrosive, meaning it will eat away at the metal IHS on the CPU.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/267286-best-thermal-compund/#findComment-3647254
