Blacking out LED case fans, how do to do it?
Solved by Laederem,
#breakthebulbs
LED lights are very difficult to break
you could probably cut the cable to the led or rip the leds out.
other wise no. the only way to do it properly is to get fans with out leds.
You can do this depending on the wiring. If the LED stripe on the fan is in parallel you can simply make a cut at the lead of the first light, since the strip itself will be in series.
technically if you make a cut like that, you could fix it again if you, for whatever reason, wanted LED fans again.
