I want a stand alone mic with good quality audio and noise cancellation but i don't want to spend over 100$ if possible i may spend a little more then 100$ if i see it being worth it please link the suggestions if possible.
CPUi7 5820k
MotherboardAsRock x99 extreme4
RAM16gb (4x4gb)
GPUgtx 980ti zotac amp
CaseNZXT Phantom Windowed Edition Black
Storage2tb hdd and Crucial MX 200 250 gb SSD
PSU750 watt cool master
Display(s)2 monitors both 1080p
Cooling80mm water cooling for cpu
KeyboardRazer Ultimate 2013 mechanical
KeyboardMouseRazer Hex Naga (green gloss)
Operating System windows 10
https://linustechtips.com/topic/264030-help-me-pic-a-mic/
My Car: http://linustechtips.com/main/topic/274320-the-long-awaited-car-thread/?p=4442206
CPU: i5 4590 |Motherboard: ASRock H97M PRO4|Memory: Corsair Vengance 8gbs|Storage: WD Caviar Blue 1TB|GPU: ZOTAC GTX 760 2gb|PSU: Thermaltech TR2 500W|Monitors: LG24M35 24" & Dual 19"|Mouse:Razer DeathAdder 2013 with SteelSeries Qck mini|Keyboard: Ducky DK2087 Zero MX Red|Headset: HyperX Cloud|Cooling: Corsair 120mm blue LED, Lepa vortex 120mm, stock 120mm|Case:Enermax Ostrog Blue Windowed
https://linustechtips.com/topic/264030-help-me-pic-a-mic/#findComment-3590920
Please stop making duplicate threads.
I've merged the threads.. again.
https://linustechtips.com/topic/264030-help-me-pic-a-mic/#findComment-3590944
Blue yeti or a snowball
The Yeti is well over $100
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/264030-help-me-pic-a-mic/#findComment-3591034
If you find a yeti on sale go for that
Sally: l Intel i5 4690k | | Corsair H55 | | Zalman z12 plus | | Hitachi 2TB HDD | | Samsung 840 Pro 128 GB | | ASRock Fatal1ty z97 Killer | | Corsair Vengeance 16 GB | | EVGA SuperNova 750 watt | | MSI 390 | | Windows 10|
https://linustechtips.com/topic/264030-help-me-pic-a-mic/#findComment-3591038
Zalman clip on mic, 7$.
no, just no. He asked for a mic over 10x that much...
OT: the blue snowball and samson meteor mic are good.
https://linustechtips.com/topic/264030-help-me-pic-a-mic/#findComment-3591047
I recommend the Snowball.
PC Specs:
CPU: i7-9700k  | Motherboard: Gigabyte Z390 Aorus Elite | RAM: 16GB's Team T-Force Vulcan 3000MHz | GPU: Zotac GTX 1070 8GB AMP! Edition  | Storage: 500GB WD Caviar Blue | 1TB WD Caviar Black | Crucial BX200 240GB SSD | OS: Windows 10 64-bit  | PSU: EVGA SuperNOVA G2 650W 80+ Gold | CPU Cooler: Noctua NH-D14 | Mouse: Logitech G502 Proteus Spectrum Headphones: Sennheiser HD 598 Special Edition's, HD 598 Cs | Keyboard: CM Storm QuickFire XT MX Blues Monitors: Acer GN246HL 144Hz, Acer G226HQLBbd 60Hz | Case: Phanteks Enthoo Pro.
https://linustechtips.com/topic/264030-help-me-pic-a-mic/#findComment-3591063
You said a noise cancelling mic so I'm guessing you don't pick up backround noise? I would suggest something like this. http://www.amazon.com/Audio-Technica-AT2005USB-Cardioid-Dynamic-Microphone/dp/B007JX8O0Y/ref=pd_sim_MI_16?ie=UTF8&refRID=0FC5VZZAQXNE39XKWJT0
And a stand like this so you can get it close to your mouth and not pick up backround noise. http://www.amazon.com/NEEWER-Microphone-Suspension-Scissor-Stand/dp/B00DY1F2CS/ref=pd_sim_MI_34?ie=UTF8&refRID=0FC5VZZAQXNE39XKWJT0
CPU: AMD 3600 GPU: ASUS DUAL OC RX 6750 XT MOBO: Asus Prime X570-P RAM: 16GB XPG Gammix D10 3000Mhz
PSU: Gamdias Kratos P1 650w 80+ Gold OS:Windows 10 pro Case: 4U Rackmount  HDD/SSD:Seagate 8 TB/ Patriot Scorch m.2 512GB
You can't spell ignorant without IGN...-TheSLSAMG
https://linustechtips.com/topic/264030-help-me-pic-a-mic/#findComment-3591258
As a matter of fact he asked "i don't want to spend over 100$", thus meaning a mic that costs <100$ and 7$ is smaller than 100$, sooo I was right. :)
If somebody was asking for a car under $1,000,000 would you recommend a used prius?
https://linustechtips.com/topic/264030-help-me-pic-a-mic/#findComment-3591335
It doesen't work like that... the reason I'm recommending the Zalman clip on mic is because it's great. Have it for 1 years and the quality of it is outstanding.
As for your car question, it depends, what would you use the car for?
https://linustechtips.com/topic/264030-help-me-pic-a-mic/#findComment-3591363
