Hello , I've been using Corsair H100i on my i7 4770k slightly OC'd to 4.2ghz , everything was fine for 2 months, stable without any temperature problems.(passed prime95 sfft) Lately I'm getting almost 100C on 2 out of 4 cores ,3rd core goes up to 94C and 4th stays around 80C while running games. Dropped down to 4.0 and its barely holding during 80%~ load. So far I tried resitting it, tightening screws and checked for any leaks. Should I consider my H100i busted and start looking for a new cpu cooler?  :(
https://linustechtips.com/topic/260590-problem-with-cpu-cooling/
Replace thermal paste
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
https://linustechtips.com/topic/260590-problem-with-cpu-cooling/#findComment-3551819
Well first stop using prime95.
Then buy some MX-4 thermal paste and replace yours.
https://linustechtips.com/topic/260590-problem-with-cpu-cooling/#findComment-3551831
As enderman said, stop using prime, you could be damaging your cpu when you use it as it overvolts the shit out of haswell. Thermal compound replacement is a great idea, stock compound blows. MX-4 seems to be the best you can get. I dropped temps about 10c by using artic silver 5 for my h110 and mx-4 is better.
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
https://linustechtips.com/topic/260590-problem-with-cpu-cooling/#findComment-3551846
Well ,I had a tube of Gelid Solutions GC Extreme at home so I just used it instead of MX-4 (should be similar). What should I use to test it now instead of prime95? IntelBurnTest?
I use OCCT which runs Linpack.
Current Rig
AMD Ryzen 5900X - Asus ROG Strix X570-E Gaming WiFi 2 - 32 GB GSkill TridentZ RGB
GeForce RTX 3080 - WD Black SN850 1TB  - Lian Li O11 Dynamic XL
https://linustechtips.com/topic/260590-problem-with-cpu-cooling/#findComment-3552036
The compound that comes with a cooler may not be the "best" but it's adequate.
https://linustechtips.com/topic/260590-problem-with-cpu-cooling/#findComment-3552174
As I said I have personally dropped 10c and I am not the only person I know that had similiar results. I used to hit 86c during an intel burn test now I am maxing out at 75c during the same duration of test with arctic silver 5. I am sure I would shave a degree or two with some mx 4
https://linustechtips.com/topic/260590-problem-with-cpu-cooling/#findComment-3552223
i have the i5 4690k overclocked to 4.5 on a h100i, running for about a month now with barely a temp change which sits around 61c stable. i check my temps once a week or so just to make sure nothing is going wrong using cinebench (probably not the best) if thermal paste doesnt work check the corsair software on pump usage and speeds. could be something is dialed really low or something was set wrong, id also check your volts if ur not doing a manual overclock.
https://linustechtips.com/topic/260590-problem-with-cpu-cooling/#findComment-3552259
I just tested it with OCCT , 3x 12 min test , on 4.0 , 4.2 , 4.4 , memory on 90% , 1min idle period at the beginning and the end.
4.0 Test completed , core 0/1 got to 81C core 2 78C core 3 67C
4.2 Test completed , core 0/1 got to 84C (barely finished) core 2 82C core 3 71C
4.4 Test failed after 2 min core 0/1 reached 85C and test was automatically stopped
4.4 2nd test without safety mechanism stopped after 2min58sec core 0/1 reached 101C
CPUTIN didn't go over 27C
Checked and monitored pump during tests, everything was set properly and worked as intended according to Corsair Link.
https://linustechtips.com/topic/260590-problem-with-cpu-cooling/#findComment-3552390
what volts are you at? and is it a manual OC?
https://linustechtips.com/topic/260590-problem-with-cpu-cooling/#findComment-3552407
