Terrible first build :(
I've been using laptop for 6 years. Today is the first time I build my own PC and I got all my stuff today but the RAM. I'm kind of worried right now cause I somehow screw up with the components and connectors. This is what I did:
- Unscrew and fix the CPU cooler so many times that I somehow feel I put hard force onto the CPU cover. Is my CPU still ok with it?
- Bended USB 3.0 connector but was able to put it back
- Bad cables management
- I removed the graphic card (with force) but the whole thing somehow didn't come out and and the plug still stuck in the slot. Then I put it back but I'm still worrying about it
- Some connector wasn't fully plugged. Are they alright with it?
- What does 4x pin Peripheral plug do?
I'll be receiving the RAM on Monday so I don't really know whether my PC will work or not.
I know some of my questions might sounds silly to you guys but I never have any experience in building a desktop before
Okay as a general thing you should do is to watch the disassembly video I gave you so that you understand the process should you need to take anything back out and you should read the motherboard manual on the connectors and how to put them in and which ones go where and so on. Also it would help if you took pictures of the areas in concern so that we can assess the damage done
- From the CPU is in the socket correctly, the force from a heatsink will not damage it, it's suppose to apply force onto the CPU so that the contact of the thermal paste and CPU is as vacuumed of air pockets as much as possible pretty much
- If you bent the USB 3.0 connector so much that it fell off, then I doubt it will be functional. If it did fall off, I wouldn't say it's unfixable but to reattach it, better to go to a professional or just replace the motherboard
- Cable management can be sorted later, bad cable management doesn't affect if the system will work or not but if you have cables plugged in and then twisted around so that it drags on the connectors then you are in issues
- I believe you have probably broken the latch that is used to hold a GPU upright. I don't think you've broken the actual data connectors of shiny gold that line the bottom, so if that is ok, the GPU should still work
- We dont know what connectors aren't fully plugged in but if they are needed connectors they need to be fully plugged in
- The 4 pin peripheral connector is the molex connector. Unless you have an old IDE HDD or some case fans or a pump, you won't be using this connector in anything really
