Installing CPU while Motherboard in case?
Solved by Geekazoid,
So I am building a PC, and I am buying every part at a separate time.(Whenever I have money) At the moment I have enough money to buy my motherboard or power supply.
I was wondering if you can install the motherboard into the case, without the CPU or RAM installed on it, and be able to install the RAM and CPU later on. Can you do without any problems in the future?
Thanks -Christian
Of course, although it is generally easy to install each part onto the motherboard whilst it's out of the case. ![]()
