Swiftech H240-X (280MM) or H220-X(240MM). It beats out Thermaltakes 360MM AIO.
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/255778-best-aio-watercooling/#findComment-3501537
Swiftech is indeed the way to go. You can expand them later if you want! They are bigger than most AIO's but still, i think it's worth it.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
https://linustechtips.com/topic/255778-best-aio-watercooling/#findComment-3501558
The kraken x61.Is at the top of the performance benchmarks.As for expandability swiftech is not worth the effort you will have to add more rads and fans along the way in case you want to expand also the pump is not the best actually is quite worst
Beware of him that is slow to anger; for when it is long coming, it is the stronger when it comes, and the longer kept. Abused patience turns to fury.
https://linustechtips.com/topic/255778-best-aio-watercooling/#findComment-3501579
@nanowatt. That is kind of what expanding a loop is. It's not necessarily that though.
https://linustechtips.com/topic/255778-best-aio-watercooling/#findComment-3501587
@Godlygamer23 yes but that pump is not the best and you know very well that the flow of the liquid inside is very important for cooling the faster the better.
https://linustechtips.com/topic/255778-best-aio-watercooling/#findComment-3501588
Kraken X61
CPU Intel I7-4700MQ @2.4 ghz, turbos to 3.4
Motherboard  whatever toshiba put in the thing
RAM 8GB 1600mhz
GPU  Nvidia Geforce GT 740M
Storage 750Gb 5400rpm
Cooling  Crappy laptop fan
Operating System  windows 8 64 bit
01101001 01100110 00100000 01111001 01101111 01110101 00100000 01101000 01100001 01100100 00100000 01110100 01101111 00100000 01000111 01101111 01101111 01100111 01101100 01100101 00100000 01110100 01101000 01101001 01110011 00100000 01101001 00100000 01100100 01101111 01101110 00100111 01110100 00100000 01100010 01101100 01100001 01101101 01100101 00100000 01111001 01101111 01110101
https://linustechtips.com/topic/255778-best-aio-watercooling/#findComment-3501594
