Water cooling custom loop
I'm working on a new build and I want to make up a custom water loop for it. I have the ASUS Maximus VII Formula which has a water block already on the board to add to a loop so an aio wouldn't be ideal i think. I see many people recommending a D5 pump to start with. Is this like a generic pump that many companies are putting into systems? Am I too noob to be here?
The D5 vario pump is basically one of the best go to pumps you can get for watercooling, it's made by Laing but others have rebranded them or have added features to them that the original did not have such as temp sensors or pump fail safe. It has high pressure and low noise especially for the variable speed version of the D5 one where you can turn down the speed and have it basically near silent.
