2 way GTX 980 or 3 way GTX 970 for 4K 60 FPS?
Rockyt
Hello again guys, well the title is the question, which of the 2 options are better for 4K 60 FPS gaming? Also 3 way 970 seems cheaper the 2 way 980. THANKS a ton in advance for your time and answers :)
I'd go with 2x980
Rig: I5-3570K@4.3Ghz - Cooler Thermaltake Frio Advanced - Ram Kingston 1333Mhz 8gb (2x4) - GPU GTX 970 4GD5T OC - Motherboard Z77MA-G45 - PSU CoolerMaster GX II 750w - Storage WD 500gb HDD - Sound Edifier M3700 5.1 - Headset Corsair Vengeance 1500 - Mouse Razer Deathadder 2013 - Keyboard Razer Anansi - Mousepad Steelseries QcK+ - Xbox 360 Wireless Controller x2
Obviously 3 way 970 is better, With more power, but do you really need 3 cards? I would not get 3 cards Just get 2 970's, 3 way's scaling in SLI goes downhill really fast, Use the money you saved by going 2 way 970's on improving other parts.
Also you need a decent motherboard that doesn't share too much bandwidth with other stuff like USB 3, M.2 PCIe and SATAe on the 3rd PCIe slot, If going 3 way.
But you don't really need 3 cards, The scaling is truly horrible on 3 way SLI...
2x GTX 980s, less frame dipps and visible stutters
i7 4790k | ASUS Z97 Gryphon | 8GB Corsair XMS3 1333Mhz | Asus Direct CUII GTX 770 1267/3829 | Stock Cooler | Antec Neo Eco 520W | WD Green 1TB
Silverstone TJ08-e | Klipsch Promedia 2.1 | Razer Tiamat 2.2 | LG 24EN43VS | Razer Naga (2010) | Razer Lycosa (2010)
Planned PC Upgrades: https://www.pccasegear.com/index.php?main_page=wish_lists&wlcId=325661&action=wish_lists
thanks a lot guys :D as to the MB it will be the maximus 7 hero or formula with intel 4790k
3 Way 970's crush dual 980's to pieces.
That is if the scaling is good
It seems as.scaling is around 90%. I would still go with 2 980 if i could.
Intel 4790k | Asus Z97 Maximus VII Impact | Corsair Vengeance Pro Series 16 GB 1866Mhz | Asus Strix GTX 980 | CoolerMaster G550 |Samsung Evo 250GB | Synology DS215j (NAS) | Logitech G502 |
oh and i live in India so 3 970s are actually cheaper than 2 980s xD 3 970s are like 1500$ and 2 980s are like 1620$
and to be honest, *may sound crazy* i just want to play GTA 5 in jan at 4K with ultra at somewhere around 60 FPS :3 all this is like, MAINLY for GTA 5
Then definitely 3 970's!!!!
But do you really need to spend $1500 to render pixels on your display?!
True but in Linus video about SLI you will get a better experience with 2 way than 3 way just because of the stutters that going with more GPUS bring
https://www.youtube.com/watch?v=UnS0xWtoRzk&list=UUXuqSBlHAE6Xw-yeJA0Tunw
Maybe you should get 2 970's and if you aren't happy with the FPS then you can add another in to have 3 970's.
We don't even have the system requirements for GTA 5 yet, You should just get 2 970's, and once the game comes out see how it runs, I think it will do mid-high at 4k 60fps, If rockstar optimizes the game well unlike GTA IV
The hero can't do 3 way SLI, You will need the formula.
This build will cost wayyy too much! for what it's being used for.
Honestly for 4k 60FPS id go with 2 GTX 980
the scaling is actually not that bad, plenty of AAA titles have almost perfect scaling.
We are talking about GTA V, Remember GTA IV.... If it's like that we are all screwed.
The performance difference between the 970 and the 980 is really nothing. They both use the GM204 chip, The 980 is full GM204 and 970 is tuned down a bit.
I believe the 4790k doesn't have enough pci-e lanes to do triple, as it only has 16 I believe, might be wrong though
CPU: Intel Core i5 4460 | GPU: XFX r9 280x DD BLACK OC EDITION | RAM: 8gb Kingston HyperX Fury 1600Mhz | Mobo: Gigabyte h97n-WIFI | PSU: EVGA 600B | Case: Cooler Master Elite 120 | Cooler: Stock intel | SSD: Samsung 840 EVO 120gb | Storage: WD 150 gb
CPU: Intel Core i7 4710MQ | GPU: NVIDIA Geforce GTX 850M | RAM: 8gb Corsair 1600Mhz | Mobo: Metabox WA50SJ Motherboard | Case: Metabox WA50SJ case | Cooler: Stock | SSD: Sandisk 256gb
:wub:  :wub:  :wub:
Best purchase this year, bcuz forza
the difference in games between 2 970 and 2 980 is a 20% difference
Hero won't do 3 way SLI. Would need to step up to a higher end motherboard. I'd say if you have the money just get 2 980s. Triple SLI is just asking for scaling issues
I truthfully would go for one of those 8gb 290x since its heaps of room, also 512 bus would help too in 4k
get two of those bad boys for just over a grand
Its all about those volumetric clouds
3x 970's might perform better in some games. But in some they won't, and you'll probably end up with lower minimum framerates. 3 970's also require more power, are louder and hotter, and you have to have the CPU lanes and motherboard slots to support it.
And yet, and yet...
By the way,
If you are planning to play 4K at 60fps with any of these setups you had damn well better prepared to turn some settings down. 4K gaming at 60fps is ridiculously hard.
