Need help choosing best graphics card for under $220CDN
Guest
So I am stuck between multiple cards. The games I will mostly be playing are BF4, GTAV, Bioshock Infinite, etc.
BTW my cpu is a Pentium G3258 overclocked to around 4.4ghz-4.6ghz(Please don't argue over this)
http://ca.pcpartpicker.com/part/xfx-video-card-r9285acdbc
If you could just save up a tad bit more and buy a 290... D:
This.
Save up and get a 290. It's only an extra $70. Or, get it from the US if you're close enough to the border.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
This.
Yes but again I am on a budget
I am on a budget though $600CDN
What? So how much can you spend on the GPU?
Please give us your entire specs.
#SAMSUNG  "provided us 4 1tb ssds so we could run the whole site off solid state." - LinusTech
#GALAXY
#ATIV
http://ca.pcpartpicker.com/p/mQwbcf Btw I already own a PSU
Trust me. Save up a bit more and get a 290.
PCPartPicker part list: http://ca.pcpartpicker.com/p/4tF6yc
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  ($69.99 @ Canada Computers)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($33.94 @ DirectCanada)
Motherboard: ASRock H81M-HDS Micro ATX LGA1150 Motherboard  ($51.95 @ Vuugo)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory  ($82.59 @ DirectCanada)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($54.99 @ Canada Computers)
Video Card: Gigabyte Radeon R9 290 4GB WINDFORCE Video Card  ($299.99 @ NCIX)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($47.99 @ NCIX)
Total: $641.44
Generated by PCPartPicker 2014-11-17 20:09 EST-0500
If you sincerely can't go with this build.
PCPartPicker part list: http://ca.pcpartpicker.com/p/mr8cNG
Video Card: PowerColor Radeon R9 285 2GB TurboDuo Video Card  ($219.99 @ NCIX)
Total: $561.44
Generated by PCPartPicker 2014-11-17 20:11 EST-0500
Another option: Get an i3 instead of Pentium
PCPartPicker part list: http://ca.pcpartpicker.com/p/fDvGVn
CPU: Intel Core i3-4150 3.5GHz Dual-Core Processor  ($118.98 @ DirectCanada)
Total: $610.43
Generated by PCPartPicker 2014-11-17 20:13 EST-0500
#GALAXY
#ATIV
Money can be saved. Budgets can be extended.
What we're trying to get across is that you'll get a much better experience if you save up just a little more.
You can also get the 290 for not much more than $220 from the US.
Your best bet is to cross the border to NY and find the closest Micro Center in NY (there are 4.) Not only you'll be able to make a better PC, but save a lot more. Not sure how far you are, but if you're close towards the borderline, this will be my best bet. If budge is really a problem - probably waiting for the 290 to drop in price is your best bet then.
I have been looking around and I think I may have found something else: MSI Radeon R9 280 (3 Gddr5)
but the 770 is so worth
Finish you sentence. Worth it. That's how you'd say that and it's WAY OVER 220 CDN.
It won't be much less when the Credit Card bill comes back.
As of today, $1 USD = $0.88 CDN.
OP, if you can possibly save up, get a R9-290.
As @OriginalPromise stated, if you absolutely can't, the R9-280 / R9-285 would still be perfect options.
Intel Z390 Rig ( *NEW* Primary )
Intel X99 Rig (Officially Decommissioned, Dead CPU returned to Intel)
  • i7-8086K @ 5.1 GHz
  • Gigabyte Z390 Aorus Master
  • Sapphire NITRO+ RX 6800 XT S.E + EKwb Quantum Vector Full Cover Waterblock
  • 32GB G.Skill TridentZ DDR4-3000 CL14 @ DDR-3400 custom CL15 timings
  • SanDisk 480 GB SSD + 1TB Samsung 860 EVO +  500GB Samsung 980 + 1TB WD SN750
  • EVGA SuperNOVA 850W P2 + Red/White CableMod Cables
  • Lian-Li O11 Dynamic EVO XL
  • Ekwb Custom loop + 2x EKwb Quantum Surface P360M Radiators
  • Logitech G502 Proteus Spectrum + Corsair K70 (Red LED, anodized black, Cheery MX Browns)
AMD Ryzen Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
Intel Z97 Rig (Decomissioned)
  • Intel i5-4690K 4.8 GHz
  • ASUS ROG Maximus VII Hero Z97
  • Sapphire Vapor-X HD 7950 EVGA GTX 1070 SC Black Edition ACX 3.0
  • 20 GB (8GB X 2 + 4GB X 1) Corsair Vengeance DDR3 1600 MHz
  • Corsair A50 air cooler  NZXT X61
  • Crucial MX500 1TB SSD + SanDisk Ultra II 240GB SSD + WD Caviar Black 1TB HDD + Kingston V300 120GB SSD [non-gimped version]
  • Antec New TruePower 550W EVGA G2 650W + White CableMod cables
  • Cooler Master HAF 912 White NZXT S340 Elite w/ white LED stips
AMD 990FX Rig (Decommissioned)
  • FX-8350 @ 4.8 / 4.9 GHz (given up on the 5.0 / 5.1 GHz attempt)
  • ASUS ROG Crosshair V Formula 990FX
  • 12 GB (4 GB X 3) G.Skill RipJawsX DDR3 @ 1866 MHz
  • Sapphire Vapor-X HD 7970 + Sapphire Dual-X HD 7970 in Crossfire  Sapphire NITRO R9-Fury in Crossfire *NONE*
  • Thermaltake Frio w/ Cooler Master JetFlo's in push-pull
  • Samsung 850 EVO 500GB SSD + Kingston V300 120GB SSD + WD Caviar Black 1TB HDD
  • Corsair TX850 (ver.1)
  • Cooler Master HAF 932
Thx rascal. I will probably go with Radeon R9 280 just because my parents are giving me a maximum of around 600$
