Used SSD need help on how to transfer
Solved by Lotus,
See that delete button? Every partition on Drive 0 needs to be deleted. All of them (assuming Drive 0 is your SSD, again make sure you get this right). THIS WILL DELETE ALL DATA ON THE DRIVE. Then you'll see something like:
Drive 0 (unallocated)
Select that and go from there.
Featured Topics
PietervdWiel ·
floris.rodedio ·
Posted in CPUs, Motherboards, and Memory1 -
Tamgam12 ·
LeGreatMaxiking ·
Posted in New Builds and Planning6 -
ShotTequil ·
Posted in Audio0 -
Voy ·
Posted in Programs, Apps and Websites4
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
