Need PSU for 290X lightning CF
Solved by Aniallation,
Also, I've seen that PSU's like the EVGA G2 come with some cables that are 6+2 and others that are 6+2 and 6 on the same cable to the PSU. Does it matter whether each port on the GPU gets it's own power cable, or is it okay to use the 6+2,6 single cable on these GPU's?
The EVGA 850G2 comes with 4 PCIe power cables, each with a 6+2 and a 6 pin. In your case with the 290X Lightning, I'd run two cables to each card. One for the 6 pin and first 8 pin, and the second for the second 8 pin.
Use the quote button to reply to people
