How to SSD+HDD=HDD with some of the SSDs speed?
Solved by Captain_Slow,
Raid.
PLEASE DO NOT RAID YOUR SSD WITH YOUR HDD...
sigh*
its not called RAID, it's called SSD Caching.
this will take your SSD and your HDD and combine them into one partition, and the CPU will figure out what data you use the most and place them onto the SSD automatically.
You can do this if you have an SSD, an HDD, and a compatible Intel based motherboard that supports Rapid Storage Technology.
compatible intel chipsets include:
X79, X99
Q87, H87, Z87, H97, Z97
Q77, H77, Z77,
Q67, H67, P67, Z68
here is step by step guide
http://www.overclock.net/t/1227655/how-to-set-up-intel-smart-response-technology-ssd-caching
It's NOT the same as RAID!
