Usefulness of huge CPU coolers in comparsion with small ones
Solved by LogicalDrm,
So does small cooler limit overclocking potential? Or it'll just make more noise?
Also should I bother about intake, exhaust fans or I should stick to 1 cooler for CPU?
FFans for case or just for cooler? Having it push or pull doesn't really matter, difference is only 1-3C. Two fans is better but can make more noise. Or it could be silent for same temps that make 1 fan spin crazy. Try with 1 first and add another if you feel like it.
For case fan config we need to know which case and what fans.
