Intel i7 4770 is running at high temps 55 C and corsair h100i is flashing red HELP!
Solved by LemonSpice,
Then would not the system overheat than beeing at 50~55 temp?
nope same thing happened to me exactly when he does prime 95 it will throttle to 2.3 ghz at 100c and when he puts the stock cooler on he will be amazed at how much cooler it runs
Featured Topics
Tamgam12 ·
remo233 ·
Posted in New Builds and Planning13 -
1
6
10
rickymohk ·
Posted in General Discussion3 -
Rbakker02 ·
Posted in General Discussion1 -
BaidDSB ·
Posted in General Discussion5 -
2
