I've been working on trying to decide what I wanted to do for a build around new years and have basically settled on all the parts and want to see what you guys have to say. I'm sticking with mITX and will be building two computers; one for me, which will be the first parts list and one for my nephew. Anyways, I'm looking for some input on anything that you may do differently.
1. Budget & Location
If you guys want to recommend changes use US $. I'm not super worried about the budget, but would like to keep it under $3k for my build and around $1k for the build for my nephew.
2. Aim
My computer will be used for gaming and some CAD/3D modeling work. My nephew's will pretty much only be used for gaming and multimedia/surfing the net.
3. Monitors
I'll be using my current monitor for my Nephew's computer and will be purchasing a new monitor for my computer. I'm considering having both plugged into a TV for use when watching movies or tv shows.
4. Peripherals
I've already got the bases covered for all the peripherals
5. Why are you upgrading?
My current computer while running great is 5 years old and at this point an upgrade of one item requires upgrades of everything else.
My build is listed first, my nephew's is second
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($322.98 @ SuperBiiz)
Motherboard: Asus Z97I-PLUS Mini ITX LGA1150 Motherboard  ($155.98 @ SuperBiiz)
Memory: Mushkin Redline 16GB (2 x 8GB) DDR3-1600 Memory  ($169.99 @ Newegg)
Storage: Crucial M550 256GB M.2-2280 Solid State Drive  ($155.98 @ Newegg)
Video Card: EVGA GeForce GTX 980 4GB Video Card  ($594.95 @ B&H)
Monitor: Asus VG278HE 144Hz 27.0" Monitor  ($372.99 @ Amazon)
Case Fan: Noctua NF-S12A PWM 120mm  Fan  ($14.99 @ NCIX US)
Other: WD My Cloud EX4 Diskless ($349.99)
Other: Parvum Systems ITX case Black/white ($200 or so shipped)
Other: Alphacool 240mm Radiator ($60.00)
Other: EK GTX 980 waterblock ($127.00)
Other: Swiftech Apogee XL ($65.00)
Total: $3043.77
Generated by PCPartPicker 2014-10-20 23:16 EDT-0400
CPU Cooler: Noctua NH-L9i 57.5 CFM CPU Cooler  ($39.99 @ NCIX US)
Video Card: EVGA GeForce GTX 970 4GB Video Card  ($329.98 @ NCIX US)
Case: Corsair Air 240 MicroATX Mid Tower Case  ($79.99 @ Newegg)
Total: $981.89
Generated by PCPartPicker 2014-10-20 23:45 EDT-0400
https://linustechtips.com/topic/236478-nearly-finalized-build/
you can cut the price of build 2 by about $70 if you go for a h97 board, also that PSU is a bit expensive for a situation where silence isn't crucial. also that case can fit a mATX mobo which would be better.
also I'd go for a Hyper 212 Evo as a cooler because you won't be overclocking that CPU
INTEL CORE I5 4670K | NVIDIA GTX 980 | NOCTUA NH-L9i | GIGABYTE GA-Z97X-SLI | KINGSTON 120GB V300
CM STORM QUICKFIRE TK | BENQ XL2420TE | ROCCAT SAVU | FRACTAL DEFINE R4
https://linustechtips.com/topic/236478-nearly-finalized-build/#findComment-3241239
CPU: Intel Core i3-4150 3.5GHz Dual-Core Processor  ($109.99 @ Amazon)
If you're going to get a Z97 board and OC then get a G3258, or if you don't want to OC then get an H87, B85, or even H81 board.
Either way, in an Air 240 you don't need something as low profile as a Noctua L9i
Desktop: Intel Core i5 2380P (2400 w/o iGPU), MSI H61, 8GB RAM, 256GB SP610, 500GB WD Blue, HIS R9 280, Antec TruePower Classic 550W, Inwin MANA 134, QNIX QX2710, CM QuickFire Rapid, Logitech G402
Laptop: Toshiba Satellite L40D, AMD A6-6310, 6GB RAM, 500GB HDD, Radeon R4 Graphics, 14" 1366x768
Phone: iPhone 6 Space Gray 64GB, T-Mobile $60/mo 3GB plan
https://linustechtips.com/topic/236478-nearly-finalized-build/#findComment-3241319
 I was going with a Z97 so that he could upgrade to one of the Haswell refresh CPUs w/o too much of a problem. I'm not so familiar with the h97 boards, but I'll go take a look at them. The Case is a place holder at the moment. I may or may not get a second Parvum case for the second one to go into. An Evo won't fit since the maximum CPU cooler height is only 120mm and the Evo has a height of 159mm (specs pulled from respective manufacturers product pages). Good point on the PSU, I'll go back and find a replacement.
I'm leaving the OC choice to my nephew. If he wants to get into overclocking I'll help him get a new processor (or better yet find out before I purchase). If you guys have a better idea for a CPU cooler I'm all ears. The only thing is that it has to stay under 120mm. If he doesn't care about overclocking I'll definitely not spend the money on the Z97 board.
https://linustechtips.com/topic/236478-nearly-finalized-build/#findComment-3241378
would the Corsair 250D be a better case for the 2nd build? and a corsair semi-modular PSU would save money.
plus a H-87 or H-97 m/board would be better and put the saved money into an i5 cpu.
everything else looks pretty nice,
do you need 8TB of storage?
what about the Asus 970 strix with 6 gig or ddr5 ram instead of the Evga 4 gig card.
mayb e you can save a little on the PSU with a semi or fully modular with lower watts, unless you plan to go sli or crossfire in the future, i would check with a psu calculator and see if you need all 860 watts, maybe a 600 or 750 would save you a bit.
got to love Asus components
https://linustechtips.com/topic/236478-nearly-finalized-build/#findComment-3241455
I have changed out the PSU and mobo on the second build based on suggestions. I also had completely forgot about changing that PSU on my build. It won't even fit in the Parvum case, but I'll be swapping it out for a 600w SFX PSU. The 8TB will be put to good use holding music and movies as well as all my pictures (I shoot mostly in RAW format which eats up space quickly). I was staying with reference designs because I know it will be an extremely tight fit to get everything into the case based on the build of a prototype model over on the bit-tech forums. I will probably have to see if they can stretch the case some to fit the graphics card (which would have the added benefit of giving me some extra space on the backside for watercooling components). Here are some pictures so you can see just how small we are talking here:
https://linustechtips.com/topic/236478-nearly-finalized-build/#findComment-3241506
You can overclock on some of the other series boards, you just have to put in some research to see which ones, and which BIOS versions allow it.
Honestly, if you're getting a low end CPU that can overclock like that one can, it's almost a crime not to.
Do you need to upgrade your PC now, or could you hold off?
Pascal. Worth waiting the year for, imo.
Love the look of those cases, btw.
My next build is definitely going to be mITX, likely something like the FT03 Mini.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/236478-nearly-finalized-build/#findComment-3241612
I'm going to need to upgrade for school. I would love to be able to wait a year, but 5 years is long enough for this system. This computer will probably be retired to backup duties or for visitors that just need to get on the internet. I need to be able to run programs like AutoCAD/Inventor/Solidworks. My computer can run them, but just barely. These are rough specs since Speccy won't run on the Windows Technical Preview. I'll post up revised builds in a little bit.
CPU: AMD Phenom II X4 810
GPU: 6 GB DDR2
Mobo: DFI Lanparty
Sound: SB XFI Titanium
https://linustechtips.com/topic/236478-nearly-finalized-build/#findComment-3241798
Revised build for my computer, I still need to figure out what pump and reservoir I'll be using.
Other: Parvum Systems ITX case Black/white ($100.00)
Other: Silverstone SX-600G ($139.99)
Total: $2997.78
Generated by PCPartPicker 2014-10-21 02:25 EDT-0400
And my nephew's build
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  ($174.99 @ SuperBiiz)
Motherboard: Asus H97M-PLUS Micro ATX LGA1150 Motherboard  ($104.99 @ Amazon)
Total: $925.89
Generated by PCPartPicker 2014-10-21 02:29 EDT-0400
https://linustechtips.com/topic/236478-nearly-finalized-build/#findComment-3241834
GPU: 6 GB DDR2
Mobo: DFI Lanparty
Ah fair enough that system is definitely a little on the ancient side! My computer's pushing 4 years, but it's a 2700k so it still holds its own quite nicely.
I figured if you had a 2600k a simple overclock would tide you through.
https://linustechtips.com/topic/236478-nearly-finalized-build/#findComment-3243809
For your nephew ;)
Motherboard: Gigabyte GA-Z97MX-Gaming 5 Micro ATX LGA1150 Motherboard  ($116.97 @ OutletPC)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card  ($349.99 @ B&H)
Case: Corsair Air 240 MicroATX Mid Tower Case  ($79.99 @ Micro Center)
Total: $901.89
Generated by PCPartPicker 2014-10-21 10:29 EDT-0400
"an obvious supporter of privacy"
https://linustechtips.com/topic/236478-nearly-finalized-build/#findComment-3243931
That looks pretty nice @JoaoPRSousa
I've also updated my build since news of Gigabyte making an ITX sized 970 has been announced. To be honest a standard 970/980 was to big for that Parvum case. This though; this will be perfect!
updated with the new part
Other: Gigabyte Mini-ITX GTX 970 ($329.99)
Total: $2612.83
Generated by PCPartPicker 2014-10-22 00:50 EDT-0400
https://linustechtips.com/topic/236478-nearly-finalized-build/#findComment-3249999
You are missing a PSU and a decent CPU cooler ;)
Those WC parts, what are they for?
The PSU is listed as other since pcpartpicker doesn't have it listed as an option; It's the Silverstone SX-600G. The CPU cooler is under the other parts as well. My original plan was to Watercool both the GPU and CPU, but with that mini 970, I highly doubt there will be a waterblock for it anytime soon. So I will only be using it for the CPU; which means I could probably drop it down to a 120 or 140mm radiatior. I still need to find a small pump and res that will fit in there as well as decide on hard or flexible tubing.
https://linustechtips.com/topic/236478-nearly-finalized-build/#findComment-3251676
Well, I finally found something that pulls my full system info in Windows 10. I tried Speccy, but that has an incompatibility issue. I decided to purchase a personal copy of Aida64 so I can mess around with it before I start building and Oc'ing my computer in a month or so. Anyways here are the full specs on my current ancient computer and what I will be upgrading from, as you can see this thing is ancient and I'll be making a big leap forward no  matter what I do.
CPU: AMD Phenom II x4 810 2.6GHz
Mobo: Gigabyte
Chipset: AMD 790GX / AMD k10
RAM: 6GB DDR2 800MHz
GPU: Nvidia GTX280
Sound: SB X-Fi
HDD: WD Caviar Green 1TB (SATA 2)
and 2 generic DVD burners
https://linustechtips.com/topic/236478-nearly-finalized-build/#findComment-3265047
