Hey guys,
I am planning out my new rig and I need some help for that.
I got a couple of fans that I wanna buy but they are all 3-pin - the Corsair white LED High Static Pressure fans. Even the AF fans are all 3-pin, i just wanna have all my fans in the case the same, yeah just maybe the size different, but design, i want them all same.
I want to know, since those fans will be running all the time at 100% speed, can I lower them without using a fan control? Lots of fan controllers I see on Amazon look like a "hit and miss" so I don't wanna get the headache with RMAs. I was gonna use the DIP 5 software for overclocking and optimization (from Asus), but would that work?
Just to mention, I am gonna watercool my CPU anyways using the Swiftech H240-X with their stock fans, since they are all PWM controlled... However, it's just the Corsair fans I am really concerned about, how can I manage those noisy guys?
If you want, you can even suggest me some other fans...here is the config i came up with for now...
Case: Vengeance C70
Front: Dual 120mm LED High Static Pressure fans in push + one fan on the back of HD cage for pulling. intake
Side: Dual 140mm LED High Static Pressure fans in pull - intake
Rear: One 120mm LED High Static Pressure fan in push - exhaust
Top: Dual 140mm PWM High Static Pressure fans from Swiftech - intake
PSU fan: 135mm: exhaust
Exhaust from the bottom of the case - no fans.
If there is a way to control those 3-pin case fans, tell me, or suggest me 4-pin fans. I want to control all of them with SOFTWARE.
Intel Core i9-9900K | Asrock Phantom Gaming miniITX Z390 | 32GB GSkill Trident Z DDR4@3600MHz C17 | EVGA RTX 3090 FTW3 Watercooled | Samsung 970 EVO 1TB M.2 SSD | Crucial MX500 2TB SSD | Seasonic Focus Plus Gold 1000W | anidees AI Crystal Cube White V2 | Corsair M95 | Corsair K50 | Beyerdynamic DT770 Pros 250Ohm
https://linustechtips.com/topic/236107-how-to-control-case-fans/
Do you have a particular budget? my suggestion would be Be Quiet Silent Wings 2 PWM
Intel Core i5 4690K @ 4.2Ghz | Evga GTX 780 Ti SC ACX with backplate | MSI Gaming 9 AC | 8GB (2x4) Corsair Vengeance Pro Silver 2400 MHz | Corsair H105 128GB Crucial MX100 | Toshiba 2TB | Evga 750G2 | Corsair Obsidian 750d | Be Quiet Silent Wings 2 PWM (3x140mm & 3x120mm)
https://linustechtips.com/topic/236107-how-to-control-case-fans/#findComment-3235564
You can use a program like speedfan which can change fan speed according to the temperature of your CPU. Otherwise, some MB manufacturers like Asus have programs that you can download which also control the fan speed based on the CPU temperature.
https://linustechtips.com/topic/236107-how-to-control-case-fans/#findComment-3235579
wooow that's just... omg...so they look so  :wub:  ... alright, i think that's it, im changing them all!
https://linustechtips.com/topic/236107-how-to-control-case-fans/#findComment-3235582
NoiseBlockers are great too
Idk about noiseblocker i will look into them too, but Be quiet is really looking nice to me
https://linustechtips.com/topic/236107-how-to-control-case-fans/#findComment-3235584
Not used Noise Blockers so can't comment
https://linustechtips.com/topic/236107-how-to-control-case-fans/#findComment-3235588
3 pin fans will be DC controlled by your motherboard.
4 pin fans have PWM, that means, that the speed can be changed without changing voltage, but the speed of 3 pin fans (without PWM) is controlled changing the voltage.
So it won't matter is that what you mean? If I have Dual intelligent processors from Asus, it will test and optimize my fans, even if they are 3-pin...
https://linustechtips.com/topic/236107-how-to-control-case-fans/#findComment-3235664
Right. I'm using an Asus utility right now to control my 3 pin fans from the MB.
https://linustechtips.com/topic/236107-how-to-control-case-fans/#findComment-3235676
As was said above, 3 pin fans are controlled by increasing/decreasing the voltage. Not all motherboards support this though so you'll need to find out if you can do it on your motherboard. To my knowledge Asus' board support this BUT I doubt all of them do so I'd double check first.
https://linustechtips.com/topic/236107-how-to-control-case-fans/#findComment-3235687
Wait, do you mean "Fan Xpert 3"? I see they mension it on their specification of X99-A MB...
5-Way Optimization by Dual Intelligent Processors 5
- Whole system optimization with a single click! 5-Way Optimization tuning key perfectly consolidates TPU, EPU, DIGI+ Power Control, Fan Xpert 3, and Turbo App together, providing better CPU performance, efficient power saving, precise digital power control, whole system cooling and even tailor your own app usages.
https://linustechtips.com/topic/236107-how-to-control-case-fans/#findComment-3235720
