Those temps are fine. Also use intel XTU for stress testing, nothing else.
https://linustechtips.com/topic/235790-h80i-temps/#findComment-3231102
 this was just 20seconds in.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/235790-h80i-temps/#findComment-3231150
K then tell us the temps after a couple mins...
CPU temps go to max in a matter of seconds. There is no 'warm up' time.
https://linustechtips.com/topic/235790-h80i-temps/#findComment-3231165
My 4690k is currently running stock speeds i just wanted to test temps before overclocking a ran prime95 small FFT and got temps lowest core 68c highest 75c and this was just 20seconds in.
Something surely is wrong here :(
Did it go any higher than that? If not, then those temperatures are fine and I apoligize @Enderman for that stupid quote.
https://linustechtips.com/topic/235790-h80i-temps/#findComment-3231168
Except with watercooling there is
Hey there. You are looking mighty fine today, have my virtual cookie!  :ph34r:
MY RIG: http://linustechtips.com/main/topic/34911-my-setup-gold-ghetto-gg-lots-of-pictures/#entry446883
https://linustechtips.com/topic/235790-h80i-temps/#findComment-3231174
Nope unless you have a custom loop with a large resevoir.
I can start rendering a video and my CPU temp will rise to 68 degrees C in about 10 seconds and stop there.
https://linustechtips.com/topic/235790-h80i-temps/#findComment-3231188
nope
seems abit high if i oc it would be even higher
https://linustechtips.com/topic/235790-h80i-temps/#findComment-3231191
I can start rendering a video and my CPU temp will rise instantly to 68 degrees C and stop there.
Alright, but ive had different experiences with my AIO's
Its also impossible for the liquid to go to its max temp in a matter of seconds, just saying
https://linustechtips.com/topic/235790-h80i-temps/#findComment-3231198
nope
Then that is fine. Anything below 85C is safe, you can OC it a little if you want.
The fluid is moving so fast that it transfers the CPUs heat to the radiator faster than the water will heat up.
This is why even if my CPU is at 68C my H100i fluid temperature is at around 30-34C under load.
https://linustechtips.com/topic/235790-h80i-temps/#findComment-3231217
nope
I was thinking, "Those temps are kinda iffy for stock speeds". Maybe try remounting it and using higher quality thermal paste (Not sure how good the pre-applied paste is, although probably not the issues). How are the fans running?
https://linustechtips.com/topic/235790-h80i-temps/#findComment-3231224
i guess so, currently using all stock fans, 2 120s intake one exhaust on h80i stock corsair fan.
I bought mx-4 paste and nb-eloops black editions to put in
https://linustechtips.com/topic/235790-h80i-temps/#findComment-3231285
cpu also does boost to 4ghz so yh not stock while stress testing
https://linustechtips.com/topic/235790-h80i-temps/#findComment-3231290
