my question is... is there a way of eliminating ghosting?
mechanically maybe??
by changing to better capacitors or something.
basically can I upgrade something in my monitor to eliminate ghosting
or improving response time by upgrading some parts?
thank you
|| CPU Intel i7 3770K || MOBO ASRock H77M || RAM 8GB 1600mhz || HDD 1TB 7200 Sata II || SSD OCZ Agility 3 120GB || GPU EVGA GTX 670 2GB FTW (boost core 1240mhz) || CPUCooler CM 212 EVO || PSU Seasonic M12II EVO 750W || CASE NZXT Phantom V2 (Pink-lol) || H-Phones Sennheiser HD600 || Gamepad XBox 360 Wireless Controller || Mouse Logitech G102 || K-Board CM Storm Trigger (MX Black) || Monitor Dell P2414H || AV Common Sense ||
https://linustechtips.com/topic/235583-ways-to-improve-ghosting/
Not really mate... what cable are u using?
dvi
https://linustechtips.com/topic/235583-ways-to-improve-ghosting/#findComment-3227919
Yeah not really mechanically. I would suggest just getting a new monitor.
My PC: i7 3770k @ 4.4 Ghz || Hyper 212 Evo || Intel Extreme Motherboard DZ77GA || EVGA Hybrid 980ti || Corsair Vengeance Blue 16GB || Samsung 840 Evo 120 GB || WD Black 1TB
Peripherals: Corsair K70 RGB || Sentey Pro Revolution Gaming Mouse || Beyerdynamic DT 990 Premium 250 Ohm Headphone || Benq XL2420Z Monitor
https://linustechtips.com/topic/235583-ways-to-improve-ghosting/#findComment-3227921
Ok.. time for a new monitor then
damn. thanks anyways.
https://linustechtips.com/topic/235583-ways-to-improve-ghosting/#findComment-3227942
question, is there a way to know how many pixels my monitor has so that I could make a custom resolution to match exactly the resolution to number of pixels
thank you
https://linustechtips.com/topic/235583-ways-to-improve-ghosting/#findComment-3227950
If only it was that easy....actually even it was that person would need to know lot of know how
Current system - ThinkPad Yoga 460
ExSystems
Laptop - ASUS FX503VD
|| Case: NZXT H440 ❤️|| MB: Gigabyte GA-Z170XP-SLI || CPU: Skylake Chip || Graphics card : GTX 970 Strix || RAM: Crucial Ballistix 16GB || Storage:1TB WD+500GB WD + 120Gb HyperX savage|| Monitor: Dell U2412M+LG 24MP55HQ+Philips TV ||  PSU CX600M ||
https://linustechtips.com/topic/235583-ways-to-improve-ghosting/#findComment-3227964
thank you
1920 x 1080 and check your monitor settings or contact benq if it still under warranty
ExSystems
https://linustechtips.com/topic/235583-ways-to-improve-ghosting/#findComment-3227975
What's wrong with DVI :( I still use it, and I've had better experiences with it over HDMI. Haven't tried DP though.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/235583-ways-to-improve-ghosting/#findComment-3228027
No, i didnt mean it like that. DVI is the second best in my opinion, behind display port.  I mean it as in 'its probably not the cable causing the problem'
https://linustechtips.com/topic/235583-ways-to-improve-ghosting/#findComment-3228041
Oh, ok :D I see, sorry for the misunderstanding :P
https://linustechtips.com/topic/235583-ways-to-improve-ghosting/#findComment-3228047
What monitor do you have?
@LunaticGTX460
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
https://linustechtips.com/topic/235583-ways-to-improve-ghosting/#findComment-3228122
@LunaticGTX460
benq gw2750hm va panel 1080p 60hz 4ms GTG
https://linustechtips.com/topic/235583-ways-to-improve-ghosting/#findComment-3228397
Well that's actually a VA panel equipped monitor and VA monitors are known to be slower than IPS or even TN monitors and you are gonna notice ghosting much more because of this no matter what pixel response time compensation is implemented. VA monitors are great for watching movies because of their great 3000:1+ contrast ratio and their deep inky blacks because of this. As for gaming, probably not so much. For that task I would highly recommend you an IPS or TN monitor (if you're a competitive gamer and need super fast response times) as they don't suffer quite as severely from ghosting like VA monitors do. I hope that helps you in some way. :)
https://linustechtips.com/topic/235583-ways-to-improve-ghosting/#findComment-3231408
Do you have a reliable article on this I can read? I'm quite curious on this topic. I hope you don't mind me picking at your brain.
Like watching Anime? Consider joining the unofficial LTT Anime Club Heaven Society~ ^.^
https://linustechtips.com/topic/235583-ways-to-improve-ghosting/#findComment-3231423
That was all just written from memory. I've read a lot about display panel technologies because I'm fussy about colour accuracy and wanted know what was the best panel technology for the best colour accuracy. Because of wanting to know this I did pick up additional knowledge along the way, so that's why I'm able to easily write a post like above. However, if you would like to read up on these panel technologies yourself then my first stop would be to go to no other place than TFT Central. Simon Baker does great work and he has written a whole article about the various display technologies that you can read about right here (http://www.tftcentral.co.uk/articles/panel_technologies.htm). Enjoy! :)
No, just don't touch anything major as I would like to keep the ability to walk and talk like everyone else. :P
https://linustechtips.com/topic/235583-ways-to-improve-ghosting/#findComment-3231501
Thank you!
https://linustechtips.com/topic/235583-ways-to-improve-ghosting/#findComment-3231520
Thank you!
You're welcome! :)
https://linustechtips.com/topic/235583-ways-to-improve-ghosting/#findComment-3231525
Oh.....I forgot to mention that that knowledge will cost you $500. :P JK
@MyInnerFred
https://linustechtips.com/topic/235583-ways-to-improve-ghosting/#findComment-3231638
I had an IPS monitor, it was Dell u2312hm but it had a very annoying motion blur, there was no ghosting whatsoever, but the motion blur was driving me crazy, this VA monitor doesn't have motion blur, but the ghosting is horrible,
and my friend has a TN panel, and he doesn't have motion blur or ghosting, but the backlight bleed is horrendous and the colors are washed, LOL.
Is there a monitor that is IPS with a fast response time and no ghosting that does not have backlight bleed, with a good PPI (pixel per inch)
also what is PLS? all I could find about it was that it was better then IPS.
Also is there an AMOLED monitor for gaming?
(sorry for long post)
https://linustechtips.com/topic/235583-ways-to-improve-ghosting/#findComment-3234028
