Case for Kaveri LAN build
Solved by Ghouldude,
Ended up getting the raven, bought the flat cables pack for my PSU, I'll attempt to individually sleeve the old set of cables for a better look, the radiator isn't a problem, should fit in the ventilation for the GPU, and for dual graphics or discrete later on, a single slot 750ti or 250x should get the job done. Maybe even mod that PNY 970 to be single slot. Thanks for the help, and sorry I didn't go with the ft03, but it just isn't portable enough.
Featured Topics
3
10
2
JFRStudent ·
Posted in Photography and Videography1 -
5
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
