So on my upcoming build i will be getting an H440, so can you guys tell me if this chart i made (using my mad paint SKILLZ) will be good? I plan to later on upgrade the front fans to Noctuas
Thanks :D
Are you new to the forums???? read the Code of Conduct HERE WANT SOME AWESOME LTT THEMED WALLPAPERS??? check out XTanksSlayerX's wallpaper thread HERE
"May our framerates be high, and our temperatures low" - PC MasterRace
https://linustechtips.com/topic/231564-air-flow-chart-h440/
Yes, its good.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/231564-air-flow-chart-h440/#findComment-3166163
It's good, another option to consider is having the fan on the back(with the IO or on the left hand side of the picture) as an intake meaning the only exhaust would be the top it'd help keep pressure positive and would allow the heat to rise easier straight out the top... (assuming you put fans in the top)
5820k4Ghz/16GB(4x4)DDR4/MSI X99 SLI+/Corsair H105/R9 Fury X/Corsair RM1000i/128GB SM951/512GB 850Evo/1+2TB Seagate Barracudas
https://linustechtips.com/topic/231564-air-flow-chart-h440/#findComment-3166181
but then what about the noctua cooler, wont the airflow from the noctua and the airflow from the case fan cancel each other out? and if i rotate the noctua cooler to the oterh side same problem will the right side intakes
https://linustechtips.com/topic/231564-air-flow-chart-h440/#findComment-3166193
Yes but run your intake fans at a bit higher RPM than the exhaust fans. This will give you more positive air pressure.
https://linustechtips.com/topic/231564-air-flow-chart-h440/#findComment-3166194
Yeah, that would not be a good idea to do with a tower air cooler. Leave it on exhaust and do what I said above there ^^^ :)
https://linustechtips.com/topic/231564-air-flow-chart-h440/#findComment-3166201
yea, im a headphone gamer so i can rev those suckers up, gonna have to because of retricted airflow cuz of front panel
https://linustechtips.com/topic/231564-air-flow-chart-h440/#findComment-3166204
you can put it in Push towards an intake or I believe you can aim it up and down to even further just aim the airflow straight out the top...
https://linustechtips.com/topic/231564-air-flow-chart-h440/#findComment-3166217
if i aim it up it would block the PCI slot where the GPU is
https://linustechtips.com/topic/231564-air-flow-chart-h440/#findComment-3166237
Are you sure about that? try it and double check and makesure to check if it's the fan or the heatsync itself... (sorry don't have much experience with the D15 or similarly sized double tower heatsyncs
https://linustechtips.com/topic/231564-air-flow-chart-h440/#findComment-3166304
if it does cover the first pci slot, can i plug the GPU into the next available? (there are 3 pci 16x slots)
https://linustechtips.com/topic/231564-air-flow-chart-h440/#findComment-3166319
Yeah it'll work fine...
https://linustechtips.com/topic/231564-air-flow-chart-h440/#findComment-3166323
